Old 10-20-2008, 09:34 PM   #1
mole2000
mole2000's Avatar
steering resistance after rebuild
I just got my steering parts all hooked up except for steering column. I was turning it from side to side to get access for greasing some of the fittings and was surprised at how much more resistance the system has over the manual box and old parts that I replaced. It was a real chore to turn by grabbing the wheels and push/pull to turn the system. Is that appropriate level of force for all new parts + power steering box? I couldnt find any conflicts between parts...
mole2000 is offline   Reply With Quote
Old 10-20-2008, 09:37 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: steering resistance after rebuild
yes, that's normal. You are pushing fluid through the system
Old 10-20-2008, 11:21 PM   #3
mole2000
mole2000's Avatar
even if the pump is not installed and there is no fluid yet? adding the pump and new column are my next steps...
logically the gearbox could have more resistance because it expects the fluid pressure and not my puny arms.
Old 10-21-2008, 07:58 AM   #4
JimKshortstep4x4
Make sure the adjustment screw is not too tight.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
