Its Deja Vu time again
Cross Member Mod for exhaust?
I was on Early Classic and saw this. Now I'm not in need of it at the moment since I'm not planning on sitting on my frame rails or anything that extreme As well I'm running a 2-piece shaft and a Long Bed.
http://www.earlyclassic.com/Images/t...rossmember.JPG Tired of dragging the center crossmember of your 1963-'72 GM truck? Early Classic's new Extreme Drop Center Crossmember has solved several clearance problems associated with 5" or more rear drops. Not only does our unit give your chassis 2.5" more ground clearance, it's raised center hoop design eliminates driveshaft interference on trucks with a slammed stance. This Assembly also provides exhaust passages to allow you to run 3" dual exhaust through the center of your chassis and out of harm's way. This black powder-coated beast has been engineered and fabricated from 1/4" thick Laser-cut and formed steel plate to be stronger and more functional than the factory unit it replaces. As you have come to expect from Early Classic, this component's design also retains factory brake line, fuel line and parking brake cable passages, and is provided with all necessary Grade-8 hardware. (No cutting or welding required.) (Note: Designed for use on short wheel-base, one-piece driveline pickups with 5" drop or more.) My question is can you enlarge a hole near the outer edges of the factory cross member to run exhaust though? Maybe even connect the front and rear pieces of the the cross member for additional support? Or are you taking a chance tinkering with the cross member? Last edited by kizer; 10-21-2008 at 03:19 PM. |
Re: Cross Member Mod for exhaust?
I just used a hole saw on mine.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
Are you using the factory Cross member?
Man under your rig looks so clean its amazing. |
Resistance is Futile
My truck has leafs, the exhaust guys cut it out and ran thru the x-member which keeps the exhaust up out of the way. Eventually you will have 3 things low.....your a-arms , the trans pan, and the x-member itself.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
So it sounds like my great idea is the idea.
![]() So I'm a little slow. Hahaha Last edited by kizer; 10-21-2008 at 10:54 PM. |
Yes I am and thanks for the complement.
![]() Join Date: Aug 2005
Mine's not purty yet but here's how I ran it. I welded some 3/16" wall x 4.5" tube "rings" in the holes to regain strength:
Do you think the "rings" need to be welded in? Looks like 3" pipe there?
I'm ready to do the the same thing. Tossing the full length headers and going to shortys, then running the exhaust above the trans member and through the cross member then into the mufflers. Chop |
Yep 3" pipes. I can't say for sure the rings are needed, but it doesn't hurt. The ECE TA member doesn't have them, so...? A lot of guys put them in just as a feel good measure. I guess it depends on how much power you'll be pushin.
Hollister, CA.
![]() Join Date: Sep 2006
If I were to cut out the crossmember, I would definately weld in some rings.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
SSN 706
Anybody else have pics of what they did to their cross member. How big of hole they cut / how they cut it out/ where there cut it? How they re
Hollister, CA.
I would weld in some rings or tubes...then reinforce with some thin plate...kinda like this:
- - ![]() - - Sorry, my 3D paint skills suck....but you get the idea. - - Definately overkill, and only some rings welded in is probably all you need...
#13 |
SSN 706
Do you think I should put the holes centered on the old cutouts or make the holes off to the side. Somebody said they cut them out with a hole saw do they make one for metal?
#14 |
Wow I'm glad this thread came up again because I'm still thinking of doing this.
This time I'll subscribe so I can find it faster. hahaha |
#15 | |
SSN 706
#16 |
Yes they make hole saws for metal.... I used a 4inch hole saw. I put the holes toward the frame rails where it has the wedge section missing in the middle. I tach welded a piece of scrap metal across the split section so i had a place for the pilot bit to drill on the hole saw. (If that makes any sense)
64 lwb, 3.5" Z, 500ci Caddy, 5 lug and disc brakes |
#17 |
do a search for tommys66 build on this forum. There are some pics there of how i did this.
#18 |
SSN 706
