Old 10-21-2008, 03:25 PM   #1
orbot
orbot's Avatar
Carb trouble
Hey guys.
So i recently noticed some staing and and fuel odor from my truck when i turned the engine off and i saw fuel leaking between the carb spacer and the intake man. so figured i faulty carb gasket took the carb out and i saw this in there.
does this look ok?
cleaned the carb it a bit with a cloth gave the bowls a little tweek cause i saw some fuel stains under them, so the gasket looked like a piece of paper, replaced it with another thicker one wich had the form of the intakes oppening and installed everything back on, not the first time i put a carb on so i know what i am doing. now i turned the engine over and noticed something odd on the engines sound and the rev, like if something was wrong, checked every whose, fuel lines and all ok, so got it gave it some gas felt fine then i suddenly gave it gas and let go and the revs would go lower as if the car could die.
Its a holley 600 cfm, used but in ok condition.
Any thing that could help, let me know.
Im trying to replace the carb for a 650, does this look ok??
orbot is offline   Reply With Quote
Old 10-21-2008, 04:55 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Carb trouble
If you have oil stains in the intake, it could very well be from your PCV valve.
Are you sure you hooked your choke up right when you put it back on? I see that it is a remote/divorced choke set up.
Also did you mess with idle/mixture screws?
Old 10-21-2008, 05:01 PM   #3
orbot
orbot's Avatar
Re: Carb trouble
no that carb is not mine, its one a guy is selling me.
ill check the pcv valve, no i did not move anything.
