Pat
Flowmaster or Magnaflow?
I am looking to do an exhaust and was thinking of getting a kit. I want a dual with an X cross over. Also have the stock 45 degree exit behind the tires. Do either of these company's make something like this for our trucks?? And what are you guys running Flowmaster or Magnaflow?
Re: Flowmaster or Magnaflow?
Dynomax here,,, sounds awesome and not too much humm inside the cab.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
What?
Dual Flowmaster "Big block" series, H pipe, and exiting out behind rear wheels. Nice and quiet, but sounds great on WOT.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Tot Roddin'
I don't think the any company makes a true bolt in kit. I think that LMC offers a Gibson kit for our trucks but will still require some modification.
But as far as Flowmaster or Magnaflow offering a complete kit, I don't think they do. Your local muffler shop should be able to pipe your exhaust anyway you would like.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Old Skool Club
![]() Join Date: Jun 2001
Running Flowmasters on the '69, but the redo (whenever it is done) will find a set of Cherry Bombs under it!
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Pat
you would think that my local muffler shop would, bet theirs been so many people in my area not having anything good to say.
vectorit is the big block series compatible with a small block? and i do realize that any kit might need some mods thanks keep the info coming pat |
20' Daredevil (Ret)
![]() Join Date: May 2003
Sound is subjective.... but I have only heard one set of Flowmasters that sounded good to me, and those were on a Tundra. Most of them, to me, sound tinny, with a hollow echo-chamber sound. Of course, an awful lot of guys love their Flowmasters. I just happen to prefer Magnaflows.
im going magnaflow because the muffler shop that will do it said & showed me y. Plus i think magnaflow is more of my character.
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
Trucks N Tranzams
I've got a Magnaflow set up on my 68. Great sound, stainless and it increased tq and hp as advertised. No, I didn't put it on a dyno, I just know because it runs better, especially mid range.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
Magnaflow makes a kit for our trucks. What few times I've heard Magnaflows, I really didn't care much for the sound. That's just me though. I'm not saying they sounded bad, but I still prefer Flowmasters. I see the Flowmaster vs. Maganaflow debate turning into a Holley vs. Edelbrock kind of debate.
I have the Super 40 Flowmasters on my truck. I love the way it sounds. Check it out. ![]() The "big block" mufflers stated above are simply just the Flowaster 50 Series, and yes, they will work on a small block and sound very nice IMO.
I had flowmasters on my GMC, and I have a magnaflow system on my corvette.
For my 68, I put a Pypes brand kit on my truck. It's available through summit. It's stainless and has an X-pipe in it. They have a choice of 3 different muffler types. I haven't fired it up yet, so I can't comment on the sound. Plus, mine is on a genIII engine, which sound different than the sbc anyways. Something else to consider. |
#13 |
Like a Rock!
68stepside- where does it exit and what cam do you run?. Sounds good!
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
#14 |
I had a set of Flowmaster 40s on my 54 behind a 350 with H pipe. They sounded great at idle and when on the gas but during long cruises they give a obnoxious drone inside the cab that prevented easy communication or music appreciation. This is a well insulated cab and the mufflers were located between the cab and the axle.
The Flowmasters were cut out and replaced with a set of Summit Turbo mufflers I had laying around. No more drone. If your truck is a driver then you will want to consider this. If it only gets driven to weekend cruises or you have no need to listen to tunes than the Flowmasters may fit the bill. I plan to upgrade to the Dynomax Turbos once these Summit units give it up. |
#15 | |
Tot Roddin'
#16 |
I Runnin dual Flowsmaster super 44s dumped just before the rearend |
#17 |
![]() Join Date: May 2005
you can go to their websites and listen to the mufflers.
www.magnaflow.com/04sound/04american.asp www.flowmastermufflers.com/mufflers.html i like the magnaflow 64-67 chevelle wagon with 3" pipes. www.magnaflow.com/04sound/domestic/gml.htm the flowmaster 50 Series Delta Flow - Three Chamber Mufflers sound good too. www.flowmastermufflers.com/50_delta.html
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
#18 |
c10crazy, the exhaust exits just behind the rear tire under the corner of the step fender. My cam is a Comp XE262 with Comp Magnum 1.52 roller tipped rockers and an Edelbrock double roller timing chain.
72BlckButy, Thanks.
#19 |
I am running a Dr Gas X crossover with the biggest Dynomax Super Turbos. The tail pipes exit in front of the rear wheels and it is a 3" system. I just put the new mufflers on, I previously had smaller Dynomax 3" super turbos and it was a little loud but had a unique sound with the x-pipe and equal length headers. I also have blower whine which gets loud too.
Regards, Ryan Hubbard |
#20 |
Pat
Thanks for the opinions, but i guess its all personal preference.
ill let you guys know what i decide on. Pat |
#21 |
Pat
Well i got a magnaflow performance exhuast made for 67-72 chevy pick ups. Its a 2.5 with an x pipe.
Now i was wondering how other people have gone from the 2 inch manifold to the 2.5 inch exhaust? Also i saw a thread awhile back about how to go through the frame with the exhuast? thanks |
#22 |
Moderator
![]() Join Date: May 2007
I like the way Flowmasters sound on a big block. I think that Magnaflows sound better on a small block. Just my opinion...kind of like Edelbrock vs. Holley, just have to decide which you prefer.
#23 |
I enjoy the sound of 50 series flows!!!!
1968 GMC Rebuilding Stage ![]() 2001 Camaro SS SOLD ![]() |
