Old 10-21-2008, 08:25 PM   #1
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
Dana 44 or GM 10 bolt
Quick question:
I have a Dana 44 front end on my 67. It was added by PO. He wanted disc brakes I assume.
It is bent, along with the GM 12 bolt rear axle.
I have been offered what I assume is a GM 10 bolt and GM 12 bolt out of a 69 Blazer, both are good, and the front axle is suppose to have discs.
Should I take them or is the Dana 44 so much better it is worth fixing?
No matter what I will go through them before they are installed, and my axle guy says it is no problem to straighten the axles.
What do you think?
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 10-21-2008, 08:26 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Dana 44 or GM 10 bolt
Take 'em, it's not worth trying to fix yours.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-21-2008, 08:30 PM   #3
Conroe trucker
I assume it is a bolt in?
Will the tie rods be the same?
Will the steering link be the same?
I ask since I have these new, but can return them if required.
01 C5 convertable
08 Z06
Old 10-22-2008, 06:17 AM   #4
Blazer1970
Blazer1970's Avatar
A '69 Blazer came stock with an open knuckle drum brake Dana 44, not a 10 bolt. The 10 bolt front axle was not introduced until the '77 model year. If it is a 44 it will bolt in. If it is a later model 10 bolt everything will work except the tie rod, but that usually comes with the axle. I think the steering was different on the '67, but if you already have a disc brake 44 in there, that has been dealt with by the PO.
Blazer1970 is offline   Reply With Quote
Old 10-22-2008, 08:37 AM   #5
Conroe trucker
Man I hope you are correct, I may have just dodged a bullett!
01 C5 convertable
08 Z06
Old 10-22-2008, 07:30 PM   #6
stenbrin
stenbrin's Avatar
1979 was the first year of the 10 bolt not 77, i have a stock 77 with a 44 in it. http://www.coloradok5.com/specs.shtml#1979
stenbrin is offline   Reply With Quote
Old 10-22-2008, 08:57 PM   #7
msgross
msgross's Avatar
I think it was sometime in 77 they say they changed...
Only difference is inner axle spline count (28 vs 30?) but who cares right? For a 1/2 ton axle the 10 bolt will get you around just as well as the dana. Most of all the parts are identical anyway... The 10 bolt will have a 3" axle tube so check your U-bolts and top plates...
I bolted one in my 68, steering would have been your only issue but agree that someone has changed your box (if you have power steering) already. You might need to swap calipers or find a metric banjo bolt for the 10 bolt...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-23-2008, 06:30 AM   #8
Blazer1970
Blazer1970's Avatar
They definitely started using 10 bolt fronts for the '77 model year. There were some Dana 44s mixed in for the first three years or so.
Old 10-23-2008, 10:59 AM   #9
Conroe trucker
Then it has to be a Dana.
Looks like I am in good shape!
01 C5 convertable
08 Z06
Old 10-23-2008, 02:34 PM   #10
justcuz
justcuz's Avatar
A Dana 44 will have the number 44 on the lower web just below the axle tube. If you don't see the number 44 cast into the web then it is a 10 bolt.
Also 10 diff covers are more round in shape a Dana 44 is angular shaped kinda like a Stop sign.
justcuz is offline   Reply With Quote
Old 10-29-2008, 03:46 PM   #11
Conroe trucker
Roughly how long did they make the 12 bolt rearend for 67-72s?
What I mean is, I need one, and did they stay the same through 77 or later?
Diameter the same?
Looks like the rear axle is toasted.
01 C5 convertable
08 Z06
Old 10-29-2008, 04:13 PM   #12
justcuz
justcuz's Avatar
12 bolts were used till about 81 or 82. What happened to the Blazer axles?
You might want to look at a six lug 14 bolt semi-floater. These are huge axles that are rated for 5000 ft lb of torque and have great big brakes too. These came in 3/4 ton trucks starting in the early 80's and the axles can be swapped out for 6 lug axles and drums.
Old 10-29-2008, 05:41 PM   #13
Conroe trucker
The Blazer axles all of a sudden came with a Blazer chassis, among other things.
I do not need a chassis.
I would like to find a 14 bolt, and that is an option.
Are they the same width?
Are the spring perches the same?
01 C5 convertable
08 Z06
