Old 10-21-2008, 08:36 PM   #1
19GMC63
19GMC63's Avatar
heater wheel question
I have a stupid question for you guys.
Is the heater fan supposed to spin independently from the shaft? I can hold the shaft and spin the wheel, although it doesn't spin well.
I bought a new blower motor since mine was bad and used the old wheel, but the wheel seems to have a lot of movement even though the nut is tightened all the way. Did I forget something like an alignment bushing or something? Or is my old wheel bad?
It seems to be blowing air,but it makes a loud racket that increases with speed... the noise is exactly what you would expect from this problem... just the intermittent noise of the wheel catching the shaft.
thanks
19GMC63 is offline   Reply With Quote
Old 10-21-2008, 09:21 PM   #2
283 Man
283 Man's Avatar
Re: heater wheel question
sound like the wheel is out of balance or bent. I had to replace mine today with a spare one I had
283 Man is offline   Reply With Quote
Old 10-21-2008, 09:36 PM   #3
TimE
Hey Y'all!!
TimE's Avatar
I bought a replacement blower motor for a '76 that I used to own and the shaft on the new motor was slightly different. Just different enough that the squirrel cage would not tighten up properly. All I could blame it on was the Chinese!! I don't know if this could be what your problem is or not. Compare the new and old and see if there may be a slight difference that you haven't noticed. Good luck.
TimE is offline   Reply With Quote
Old 10-22-2008, 10:48 AM   #4
65ShortStep
In one of the threads about this, they mention the retaining washer under the fan to keep it aligned right. Did you re-install that washer? Sounds like that might be the problem.
http://67-72chevytrucks.com/vboard/s...wer+motor+cage
post #4 in link above.
65ShortStep is offline   Reply With Quote
Old 10-22-2008, 01:50 PM   #5
19GMC63
19GMC63's Avatar
ah ha! I must of lost it when I was banging the old motor shaft with the BFH. Must of rolled under the workbench or something.
Thanks a bunch shortstep.
Old 10-22-2008, 02:02 PM   #6
65ShortStep
no problem
Been researching it myself. Just read that yesterday so it kind of stuck in my head.
