10-21-2008, 09:14 PM | #1 |
vw guy & now c-10 guy
engine tranny question
ok, bear with me, Im new to the Chevy world...
My new truck is currently 3-sp manual...Can I bolt up a 350 auto to the 250 I-6 that is in my truck? If so, what do I need to do it? Thanks guys, I'm learning... |
10-21-2008, 09:24 PM | #2 |
its all about the +6 inches
Re: engine tranny question
very easy swap, and could have been ordered stock this way... but not many were.
A TH350 would be the easy way, common, and plenty strong for any use you'd put it to... Parts list; Tranny Converter Converter bolts Flex plate Tranny cooler lines Tranny cooler, or a rad with built in cooler. Shifter (recomend aftermarket kind, stock style can be a pain in the rear toset up/locate all parts) Automatic tranny cross member Tranny mount Possibly need a speedo cable. (length issue) Starter Most, if not all of this can be obtained at a junk yard from any automatic equipped truck. (67 - 72) Drop the old tranny and bellhousing, pull off the flywheel, drill out rivits holding tranny mout arms from the frame and throw into the scrap pile. Measure the two trannys, if the length is not the same (give or take 1/4 inch) then send out the driveshaft for mods. install flex plate install tranny install mount on tranny if not done already install cross member install driveshaft run cooler lines install new rad or very big stand alone cooler install shifter lotsa tranny fluit (replace the filter too if you are installing a used tranny) Install speedo cable Tail lights and tire smoke... have fun. |
10-21-2008, 09:49 PM | #3 |
thanks for the quick reply- thats what I figured, just wasnt sure
