Exhaust ideas
I need to do the exhaust on my truck, does anyone know where I can get the pipe and if I can get pre-bent sections, like "S" bends, "U" shaped bends etc?
What is the typical price range if I have it done? I'm coming from the headers under the truck and it will exit about 1 foot behind the cab, between the rear wheel well and the front of the bed.
R.I.P. Scott Kalitta
Re: Exhaust ideas
My exhaust set me back $425.00 and it was from my headers all the way to the back of the truck right under the bumper.
All the piping, dynomax mufflers stainless installed.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
its all about the +6 inches
Re: Exhaust ideas
exhaust prices vary tremendously by reigon. No tellin why... but they do. The best i could find here in town was 100 bucks to join the manifolds to an existing daul exhaust system.
Yeah, ouch |
Re: Exhaust ideas
WOW, I think I might be better off finding the pipe and doing it myself. Any ideas where I can get the pipe?
Re: Exhaust ideas
I'll try to take some pictures of mine tomorrow. I came off headers, through the support where the drive shaft goes through and dumped right in front of the axle.
![]() Join Date: Feb 2008
Re: Exhaust ideas
Jegs, Summit or look in some on the trade magazines, like Classic Truck, will guide you to pre bent exhaust pipe. All of them have systems where you cut to fit. Patience is the key once you find the pipe your want. Keep fitting until it's where you want it to be or you'll be unhappy later with the results. Good Luck.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
Re: Exhaust ideas
If you dump infront of the rearend it saves $ with all the bending.
0.02
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Project underway - finally.
Re: Exhaust ideas
If you can weld and want to do it yourself, there is an ebay store (I think) that sells mix up bends, that are all mandrel bent, for really cheap. The problem is that you don't know what you get. It's still way cheaper. I've never tried them though, so beware.
-Brian
1972 GMC Pre-resto... awaiting allocated funding. |
Re: Exhaust ideas
i bought an x pipe block hugger headers a few 2 1/4 manderel bends and 10 feet of pipe from local speed shop for $230 am puting x pipe @ rear of trans tucked as tight as i can then into hearthrob turbo tubes over rearend and then out behind rear wheels
Re: Exhaust ideas
i do exhaust for a living and if you dont know what you are doing pay the money and have it done right. here in washington state a dual job with flowmaster mufflers will run ya about 400 bucks. there is a lot more involved than just putting some pipes and muffs on your rig. theres nothing worse than a rattle or a broken hanger or pipes hanging down. that stuff drives me nuts!
myspace.com/southtacomaalleyrally |
Between Trucks...
Re: Exhaust ideas
I got my exhaust coming out in front of the rear wheels. I already had the mufflers, cost me 2 bills to have it done at a shop.
Beat it to fit, Paint it to match... ![]() |
the boat guy
Re: Exhaust ideas
i would say the biggest price difference would be if you wanted the exhaust run cleanly through the frame or hangin down like a farm truck. id pay someone to go through frame but if i didnt mind the exhaust hangin down i would do it myself.
the guy that bent my exhaust has several of our trucks and has the exhaust throught the frame on all of them, it still took him 6 hours to get the bends right!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#13 | |
Re: Exhaust ideas
