Old 10-22-2008, 02:50 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Air valve questions
Hey guys, I have a few questions on air valve sizing
I have 2 ART Ride Pro Es, one with the Big Red 1/2" valves & the other with the smaller valves they sell
My question is, since Im not wanting to hop or anything I dont think that running 1/2" line is necessary, especially in the rear
So do I run my 1/2" valves with smaller line, like 3/8" or do I run the smaller valves which are set up for 1/4" line ???
Any vids of speeds to compare to would be great
Thanks, Matt
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-22-2008, 10:50 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Air valve questions
I would run what ever you had and put in something that would restrict it like a flow control. They also make 1/2" pipe fittings (felame to male) that are "blanks". You would just drill what ever size hole you want in them. I went with 1/8 holes on mine.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-22-2008, 11:19 AM   #3
LowSmoothCool
Jon@AirRideTech
LowSmoothCool's Avatar
Are they both 2 way or 4 way? I preffer the 1/4 over half for the adjustability and it's still plenty fast depending on the volume of air and pressure, you should expect a 3-4 sec. rise time out of the 1/4" vs. a 1-2 sec rise time with 1/2" but make sure if you are bagging all 4 corners that you are running an individual wheel set up
Selling The best Damn Air Suspension
www.ridetech.com
jon@ridetech.com
(812) 482-2932
LowSmoothCool is offline   Reply With Quote
Old 10-22-2008, 02:28 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Both set ups are FBSS
I think Ima see what the 1/2" valves with 3/8" line does, as I have 3/8" line running out of my bags right now
Sinister
Killer
Old 10-22-2008, 02:48 PM   #5
ca180
tryin to get laid
You could install ball-valves... then you could have an adjustable speed.
ca180 is offline   Reply With Quote
Old 10-22-2008, 02:51 PM   #6
ENHANCED AIR RIDE
Fittings are available that can go from 1/2 -3/8 or 1/4". So use whichever you preferor want.
BTW I carry thos e fittings in stock if needed in PTC or compression DOT or non.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 10-22-2008, 02:56 PM   #7
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sinister
Killer
Old 10-22-2008, 03:18 PM   #8
LowSmoothCool
Jon@AirRideTech
Are you running our E2 control system? the reason I ask is because with our E2 you can control your valve speed to slow them down to aquire your desired ride height.... As for the fittings I recommend DOT PTC fittings much easier and user friendly....
www.ridetech.com
jon@ridetech.com
(812) 482-2932
Old 10-22-2008, 06:29 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Jon, both my systems are the original Ride Pro E
Optimally I would love to have a Level Pro system, but funds just dont allow
One is used & the other is NIB
Sinister
Killer
Old 10-22-2008, 07:08 PM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
These are the little valves I have
I also have the Big Red valves
Sinister
Killer
Old 10-22-2008, 07:22 PM   #11
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I wouldn't run 1/2". I had it on my 69 and it was too fast. Im putting 3/8" on my Sub. Plus all the fittings are typically cheaper so thats a plus and its easier to bend.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 10-22-2008, 09:44 PM   #12
61Flattop
set it up with 3/8... if it is too fast, insert a piece if 1/4" inside the 3/8 airline. BTW.. the RideProE2 will not physically change the inflate or deflate speed. The speed adjustment is relative to the auto system. That setting determines how long the ECU will hold the valve open. The higher the setting the longerit holds it open. Lower setting and it holds it open for a less amount of time.
61Flattop is offline   Reply With Quote
Old 10-23-2008, 09:28 AM   #13
LowSmoothCool
Jon@AirRideTech
Thanks for the tecnical break down i was keeping it short and sweet
www.ridetech.com
jon@ridetech.com
(812) 482-2932
Old 10-23-2008, 03:05 PM   #14
fastbagged68
fastbagged68's Avatar
I'm running 1/2" valves with 1/2" line from the tank to the valve, and 1/4" to the bag. This is the right speed. It doesn't get up aburptly. It also make it slower on the way down too.
fastbagged68 is offline   Reply With Quote
