Old 10-22-2008, 11:46 AM   #1
Hittman
H2 wheels
No doubt this question has been posted before....I couldn't locate anything with the search. Will 2003 up Hummer H2 18" wheels work on my 1970 3/4 Ton 4x4? I found a chrome set with decent tires for $250. Just want to make sure the offset will work and no rubbing will occur. Will they need special lugs?
1970 C20 350 4-Speed no options but only 56K original miles.....Now a K20 mutt with a SB400!
2002 Impala LS (wife's car)
Hittman is offline   Reply With Quote
Old 10-22-2008, 02:39 PM   #2
lks dcvn
lks dcvn's Avatar
Re: H2 wheels
They should work - 8 lugs are all 8x6.5 for Chevy/Hummer - Fords changed patterns to metric around 1999 (I think).
Different Lugs - yes - you will need to get 32 of the double threaded lug nuts (if you intend to run center caps) - rear dually caps from mid 80s-early 90s will work. Board member 72 Freak has a set on his Suburban and they look great - if you have ? - you may want to track him down as well.
Not sure of the thread size on 70s - my 72 uses 9/16ths thread - not sure if that is standard between years or not though. I would hate to steer you wrong. Double check what you have.
They are cheaper and easier to find here (no relation or vested interest) - just who I used - http://www.ezaccessory.com/GM_9_16_E..._p/98-0009.htm
I found one of their auctions on ebay - and bought them - $32 shipped (if I recall correctly).
Here is another post to assist you (or ask questions to the owners).
http://67-72chevytrucks.com/vboard/s...d.php?t=132709
lks dcvn is offline   Reply With Quote
Old 10-22-2008, 03:44 PM   #3
70rs/ss
70rs/ss's Avatar
Re: H2 wheels
I have a set of the 17"'s and they bolt right up and the offset isn't too bad either.
70rs/ss is offline   Reply With Quote
Old 10-23-2008, 04:06 PM   #4
Hittman
Re: H2 wheels
Hey, thanks a bunch for your input and the link. I would love to see how these wheels look on our trucks before I get carried away. Anyone got pics of their trucks with Hummer H2 wheels?
Old 10-23-2008, 06:45 PM   #5
70rs/ss
70rs/ss's Avatar
Re: H2 wheels
I have the wheels and the truck, just no tires!!
Old 10-23-2008, 09:50 PM   #6
barraza
Re: H2 wheels
They're 17 inch. I have them on my 72 4x4 with the stock h2 tires. They fit great but are close enough to barely rub the drag link end where it attaches to the pitman arm on full lock right turns. I had to adjust the steering stops on that side out a little. I think they look good, but I run them without a center cap. Sorry, no pictures on this computer. A search may find some.
barraza is offline   Reply With Quote
Old 10-24-2008, 03:50 PM   #7
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Re: H2 wheels
Board member Brewski's truck.
This truck had a 4 inch lift.
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 10-25-2008, 06:17 AM   #8
heyjoe
Re: H2 wheels
What about a '67 4X2 C20, stock height. I have a set of H2s collecting dust. Anyone have any pointers on tire size that would work in my situation?
Maybe I should pose this question in a new thread.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
heyjoe is offline   Reply With Quote
Old 10-25-2008, 08:15 AM   #9
vtblazer
vtblazer's Avatar
Re: H2 wheels
Here's a set on some one tons.
vtblazer is offline   Reply With Quote
Old 10-25-2008, 11:32 AM   #10
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Re: H2 wheels
are the H2 rims 6 lugs???
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 10-25-2008, 06:22 PM   #11
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: H2 wheels
The H2 rims are 8 lug.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
