Old 10-22-2008, 05:07 PM   #1
Mike J
vw guy & now c-10 guy
Mike J's Avatar
6-lug Corvette rally and disc brakes- yes or no?
Ok, next question... Im getting the 6-lug dropped spindles and disc brake conversion... I also wanna get the the 6-lug Corvette Rallys that Wheel Vintiques sells... Anybody know if the 15x7s fit over the discs ok? ok then, How about the 15x8s? they both have 4.0" backspace if that helps... and is 15x8 too wide to be slammed on 215/70/15- will they rub? thank you thank you thank you for all your help guys!!!
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 10-22-2008, 05:45 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: 6-lug Corvette rally and disc brakes- yes or no?
yep, they will work fine. here's evidence.....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-22-2008, 06:50 PM   #3
Mike J
Mike J's Avatar
thanks Doug! What size wheels and tires are you running in the pic? thanks again...
'68 long fleet
My Build Thread
Old 10-22-2008, 10:01 PM   #4
tcb-1
tcb-1's Avatar
those were 275/60/15's w/ 15 x 8's. I have since went to 15 x 7's w/ 235/70/15...... so both will work!
and those wheels were made by Wheel Vintiques.
Doug
Old 10-23-2008, 06:08 PM   #5
northerngmc
northerngmc's Avatar
Use caution as from what I have read on here not all rally wheels will. I will try and search, but there is a diagram posted showing the different shapes and which one will work with disk brakes.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 10-23-2008, 06:18 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have Wheel Vintiques "Pre-71 truck" Vette-style rallye wheels on my truck, too. It has ECE conversion from drums to discs, and the 15x8's with a 4-inch backspace fit perfectly. The wheels are centered on the rotors and do not rub on the inside of the front wheel cutouts unless you're in a hard turn and the suspension bottoms out....something that only happened one time in the past 7 years. Without the same backspace, converting to discs may cause a lesser backspace wheel to stick further out and maybe even beyond the edge of the fender opening. I had to use 15x7's before I went to these wheels from Wheel Vintique. www.summitracing.com is where I got mine.
Member Nr. 2770
