Old 10-22-2008, 05:17 PM   #1
drewdude92
72 chevys 4 life
drewdude92's Avatar
need some help on this one...
Im looking at this motor on jegs its just a stock 350 crate motor but i want a lil cam in it for that sweet sound that i love i just need to know a good cam that i could put in this motor when i get it or is that even a good idea?
well here are the specs of the crate motor here..
4-bolt main with 2-piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam (.383''/.401'' and 112° lobe separation)
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Left and right hand dipstick
4-quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
Recommended spark plug: Accel #111-574 or any spark plug with 14mm .460'' reach, 5/8'' hex, tapered seat, projected tip
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 10-22-2008, 09:16 PM   #2
t&tkennels
t&tkennels's Avatar
Re: need some help on this one...
I think a 268 high energy cam from comp cams would be good.
t&tkennels is offline   Reply With Quote
Old 10-22-2008, 10:36 PM   #3
dan42
dan42's Avatar
Lots of threads on cams - do a search, you should find more than you need. Sounds like a great motor.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 10-23-2008, 01:42 PM   #4
drewdude92
72 chevys 4 life
drewdude92's Avatar
alright thanks im pretty sure that would void the warranty with me doing this? ill read on the warranty some more i guess
Old 10-23-2008, 03:57 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Call a cam company.They will ask about a thousand questions but they will also set you up with a cam that works for your,vehicle,driving style,gearing,tranny and any other thing you can think of.This is what they do for a living and it's free.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-23-2008, 07:06 PM   #6
drewdude92
72 chevys 4 life
drewdude92's Avatar
a cam company sounds like a good deal? where in the world would i find that number?
Old 10-23-2008, 07:13 PM   #7
cdowns
cdowns's Avatar
google
Old 10-23-2008, 09:01 PM   #8
t&tkennels
t&tkennels's Avatar
on comp cams website , theirs a section on there where you can type in all the specs on your truck , & they will email you back with a cam suggestion.
Old 10-23-2008, 11:30 PM   #9
drewdude92
72 chevys 4 life
drewdude92's Avatar
sweetness to compcams i go!!
Old 10-24-2008, 08:51 AM   #10
71tahoe
71tahoe's Avatar
I'm going to say that you definitely will void the warranty. Also, if you plan on doing it yourself I think there is something about a qualified mechanic installing it for the warranty to be in effect anyway.
71tahoe is offline   Reply With Quote
Old 10-24-2008, 06:38 PM   #11
drewdude92
72 chevys 4 life
drewdude92's Avatar
hmm i think ive pretty much decided that ima just rebuild an old block i got sitting around i want around 300 hp with a pretty sweet cam in it i just like the sound of it. Any good kits combos you all would recomend?
Old 10-25-2008, 05:44 AM   #12
Gray Ghost
Gray Ghost's Avatar
Best idea yet...I'm not a fan of GM crate motors. The 268 cam is OK but if you want a thumpy idle you'll want to look further up the list.
Edelbrock has some good top end kits that make a rebuild easy. Call them and tell them what you have now and what you want...they can help with the cam, heads, intake, carb, EFi, etc.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 10-25-2008, 07:21 AM   #13
truckdude239
truckdude239's Avatar
got all my kits at www.northernautoparts.com
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-25-2008, 09:13 PM   #14
drewdude92
72 chevys 4 life
drewdude92's Avatar
yup im still lookin around ill prob have to tear into my motor a lil more before i give them a call to tell them what i have?
Old 10-25-2008, 09:30 PM   #15
Gray Ghost
Gray Ghost's Avatar
Not really....give them the block casting number [driver's side near the firewall behind the valve cover]
and tell them what you will be doing the most with your truck. They will ask what transmission and rear axle ratio you have and maybe another question or two, then they should be able to give you an answer.
Kelly
Old 10-25-2008, 09:35 PM   #16
drewdude92
72 chevys 4 life
drewdude92's Avatar
alright hmm wish me luck gettin to that darn number...i think i can do it with a mirror though i know what tranny im have but rear end ratio i have no idea im pretty sure its the original but dont know any way to find out?
Old 10-25-2008, 09:39 PM   #17
Gray Ghost
Gray Ghost's Avatar
I hear ya...that one is a hard one to get to but with a very bright light it's not too bad.
Alternate plan....go 60mph and record your rpms. Then measure your rear tire height at the tread there's an online calculator [don't have the link but I'll bet someone does] that figures axle ratios for you given the above info.
Kelly
Old 10-25-2008, 10:01 PM   #18
drewdude92
72 chevys 4 life
drewdude92's Avatar
hmm sounds easier than it is because my speedo is way off? lol ill have someone set cruise at sixty in front of me i guess and i measure the tread to the brim of my rim?
Old 10-25-2008, 10:49 PM   #19
Gray Ghost
Gray Ghost's Avatar
You measure the tire's height....from the pavement to the topmost tread in the wheelwell. Probably 27" or more up to about 30" tall.
Kelly
Old 10-25-2008, 11:19 PM   #20
drewdude92
72 chevys 4 life
drewdude92's Avatar
o der der der lol ill do that tomorrow
