Old 10-22-2008, 06:52 PM   #1
Gray Ghost
Gray Ghost's Avatar
Show me your blazer tank pics and filler neck...
I just got a blazer tank ordered from a forum member and I have no idea which filler neck I want. I think this is a 21 gallon tank so I'd like to see what it will look like from the back.
I am thinking about a bed fill neck...anyone do one in low buck mode?
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 10-22-2008, 08:44 PM   #2
Mudder
Mudder's Avatar
Re: Show me your blazer tank pics and filler neck...
Mine came out under the fender under the bed when I first did mine, then I moved it into the bed. The big thing is clearance for the fill between the bed floor and frame and having enough fall for it to fill. Any way I have some body lift on this one.
Mudder is offline   Reply With Quote
Old 10-24-2008, 08:36 AM   #3
Gray Ghost
Gray Ghost's Avatar
Cool...is that the ECE filler cap? this is exactly what I want to do in my bed but the surface is factory ribbed steel.
Kelly
Old 10-24-2008, 08:41 AM   #4
69long"n"low
69long"n"low's Avatar
looks marine to me you can pick them up for under $50
- Josh
Im not white trash, I'm one step above that..... more like white clutter
69long"n"low is offline   Reply With Quote
Old 10-24-2008, 09:03 AM   #5
Mudder
Mudder's Avatar
Yes it's a marine cap. Most boat places handle them. I used a brass elbow on the bottom side.
Old 10-24-2008, 09:52 AM   #6
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Mine wasn't exactly "low buck" but it can be done with a junkyard fuel door. One thing I did to my tank was to cut the filler neck short, then welded on a piece of exhaust tubing of the same diameter to make it angle over the frame better, instead of up toward the bed floor. That gave me a little more room between the frame and the bed floor.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-25-2008, 05:53 AM   #7
Gray Ghost
Gray Ghost's Avatar
Here's another question...there are no fuel lines past the cab right now...is there a kit out there that I can get or do I have to make the lines myself from tubing?
Kelly
Old 10-25-2008, 10:49 AM   #8
glock35ipsc
I got my lines from NAPA. They sell them in different lengths, but I don't remember if I bought 4' or 5' sections. Then buy the fittings that tie the two lines together. Some clamps and a decent tubing bender and you'll be done in no time! Check my build thread in my sig below. On the first few pages you should be able to see the 3/8" line on the right side of the frame.
Bob
Old 10-25-2008, 12:31 PM   #9
SCOTI
SCOTI's Avatar
Any tubing manufacturers will have options for Blazers. That's where I would start.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-25-2008, 06:53 PM   #10
Gray Ghost
Gray Ghost's Avatar
Thanks for the info....I will need custom tubing since I have a long bed, so I'll just get tubing and fittings from the local OR's up the street.
Next weekend is the redo....gonna carpet the interior & maybe rework my console at the same time since I'll have the seats out.
Kelly
Old 10-25-2008, 07:33 PM   #11
SCOTI
SCOTI's Avatar
.... I will need custom tubing since I have a long bed . .....
Suburbans use the same gas tank as a Blazer . . .... and are longer .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-25-2008, 07:40 PM   #12
Gray Ghost
Gray Ghost's Avatar
Hey now...that's a thought....thanks! I only have two days to do this....a pre-bent line sure would be a nice idea....especially if all I have to do is cut it once!
Kelly
Old 10-25-2008, 07:44 PM   #13
SCOTI
SCOTI's Avatar
The main reason I suggest it is because I was going to bend my own but instead used some of the pre-fab style stainless hard-lines for the front brakes on my 74. Quick & painless..... so much so that I'm going to do the same for future stuff as well. As an added benefit, fuel lines can be purchased in varying ID's just in case you need to flow more to go more!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-25-2008, 11:50 PM   #14
MonteSS454
MonteSS454's Avatar
Hey Gray, when I tried to install the tank I realized it is 95476903476098570689730947608576098x easier with the bed off, and you can run some low pressure rubber fuel line back to the sending unit. Just becareful on how you run it so it doesn't get pinched punctured or anything, I hope you enjoy it!
MonteSS454 is offline   Reply With Quote
Old 10-26-2008, 12:19 AM   #15
Gray Ghost
Gray Ghost's Avatar
Yeah I bet it is....might just be able to pull that one off if I get enough friends over here to help that day!
Kelly
Old 10-26-2008, 12:36 AM   #16
SCOTI
SCOTI's Avatar
An engine hoist, straps or chain, plus some 2x4's & it's a one man job.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-26-2008, 12:45 AM   #17
chrislehr
Engine n00b
chrislehr's Avatar
Man, I need to get this done. I have had my poly tank for like 4 mos now...
Im waiting on an insurance check coming in too. I think that might be covering the expense!
chrislehr is offline   Reply With Quote
Old 10-26-2008, 12:48 AM   #18
Gray Ghost
Gray Ghost's Avatar
True Scoti and thanks for the info about the lines and sizes. This truck might wind up a BB one day so that might be an issue down the road.
Kelly
Old 10-26-2008, 11:41 AM   #19
2bits
2bits's Avatar
Yeah, my 6 cylinder uses 5/16" lines and the V-8 uses 3/8" I don't know if a big block uses bigger than that.
I am going to use the lines from the parts store too on my swap. I figure one or two straight lines, and rubber on the ends, no bending except maybe some gradual bends as it follows the frame.
I like the marine cap in the floor of the bed.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 10-26-2008, 11:45 AM   #20
Gray Ghost
Gray Ghost's Avatar
Yep, I just ordered one. Found it at Boat Bandit....$36 shipped.
Gonna have to come up with some sort of wooden insert though as the current ribbed steel floor [why'd they do that dept.] is not set up for that.
Kelly
