Old 10-22-2008, 07:07 PM   #1
youngin'
Crew Cab static drop....
Has anyone seen or personally dropped a Crew Cab on a static setup? I have an 84' Crew Cab (not a duallie), and I want to get her low, but I can't afford the air ride...yet? All help is appreciated.
youngin' is offline   Reply With Quote
Old 10-22-2008, 09:49 PM   #2
61Flattop
Re: Crew Cab static drop....
to do it cheap and not double spend any money, you can get you a set of spindles for the front end because you will want them anyway then you can dearch your springs. That way when you get airride you arent throwing any money out the window
61Flattop is offline   Reply With Quote
Old 10-23-2008, 01:38 AM   #3
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I agree spindles are a great investment for up front and will continue with your air system but on the rear I would say go ahead and spend the dough for a flip-kit. you'll have a better ride and unless you pull leaves you'll retain load capacity. It can be sold once you're ready to go air in the rear and really isn't a big expense.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 10-25-2008, 09:05 PM   #4
duceducenine
duceducenine's Avatar
heres mine with 2.5 drop spindle and cut coil and removed leaf springs
duceducenine is offline   Reply With Quote
