emergency brake system pics
Hey guys i need some pics of how the cables from the rear end come together and hook to the cable coming back from the pedal.
Both of my cables leaving the axle are the same length and i am missing parts so I would like to know what im looking for. Thanks in advance.
http://67-72chevytrucks.com/vboard/s...d.php?t=304940 |
Wide n'Low
![]() Join Date: Jan 2007
Re: emergency brake system pics
Here is an ok graphic from LMC Truck.
http://www.lmctruck.com/ICATALOG/CC/full.aspx?Page=154 ![]() I may have some from my truck as I was putting it back together
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
I've got a related question...about half the time, my parking brake won't "lock down" when I push it in, or will barely catch. Does anyone know how to adjust it?
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
How far are you having to push it down? You adjust it under the truck. There will be a bolt/nut, just tighten it to make it tighter.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#5 | |
(Suicide, did not mean to hijack your thread) |
Thanks ,boy i feel like a big dummy now Ive looked through the lmc catalog a billion times.
If it isn't catching I would check the latching mechanism. You may be missing spring or it bent.
BTW, you should only have to press it down about 6". If it is going to the floor it should be adjusted.
