Alright Alright Alright
using a helicoil on an aluminum intake
today i was installing a carb on my motor which has an aluminum performer RPM intake. i stripped the rear driverside bolt (the bolt was spinning) and the only repare i can think off is to use a helicoil. is this a possibility for an aluminum intake? has anyone ever tried this?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Fabricate till you "puke"
Re: using a helicoil on an aluminum intake
Yes, that works.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
1969 Short, Fleet, and Beat
do yall know who supplies helicoil kits?
Most auto stores will carry helicoils with the appropiate drill bit in a kit..if all else fails, Grainger catalog.
Any parts store hould be able to get you some variation of a heli-coil set. It may not be the heli-coil brand name, but they all work the same for me.
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
You're going to drill it oversize for a helicoil so why not just drill it for the next size bolt and tap the threads . I.E. if it's 1/4 20 make it 5/16ths 18, or 5/16ths 24. I realize it won't work if the carb base won't accept a larger bolt.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Trucks N Tranzams
I usualy just tap mine for the next biggest bolt. It has always worked for me. Sometimes helicoils are a huge pain.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
2WD Jimmy
![]() Join Date: Mar 2005
Dont feel too bad. I did the same thing last week on mine... just the passenger side. When you get it Helicoiled, dont forget to use a little anti-seize compound on all your studs/nuts.
I have an old bud that would purchase a NEW intake, & install helicoils in every threaded hole before he installed it! His theory was , after he fixed it, it was better than new(LOL)! At any rate, a properly installed helicoil , will cause less problems than threads in aluminum castings(maybe thats why edelbrock heads have helicoils installed in the exhaust side, & under the rocker studs)? The biggest problem I have seen with a heliciol repair is the lenght of the helicoil ......most parts houses will sell you a 3/8,or 1/2" long helicoil. That dont work really sweet on a 3/4 or 1" deep hole
personally i will never use a helicoil if i can get a TIMESERT. 100x better IMHO as a bike tech.
Timesert is new to me....I need o look them up, thanks
#13 |
whichever way you decide to go with your repair//over the years i've gotten into the habit on aluminum manifolds of installing studs to mount the carb so as not to have this problem in the future
#14 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#15 |
i use antisieze so they can be removed if needed in the future
#16 |
Helicoils work very well. I know of people that install them even before the have a problem.
#17 |
Crazy Longhorn and I must share friends because I know a couple of guys who do the same thing.
Usually you can get Heli coil kits at NAPA but many hardware and fastener stores have them. I've done the drill and tap to the next larger size before but that gets to be a pain in the tail end when you go to swap carbs or other pieces around. |
#18 |
I hope you will be pulling the intake so you don't have a bunch of aluminum filings floating around your engine.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#19 |
yeah, i plan on removing the intake.
#20 |
Between Trucks...
I did one a while back, left the intake on the motor. Just use a shop vac.
Beat it to fit, Paint it to match... ![]() |
#21 |
#22 |
They are steel threaded inserts. Much better. I stole this pic off the net. Last edited by mbgmike; 10-23-2008 at 06:44 PM. |
#23 |
Kid's Mechanic
Had the same thing happen a few months ago,heres a link to a sister site
http://www.streetcruizin.com/forums/...ad.php?t=19765 |
#24 |
i installed 4 of them in an aluminum bellhousing.the transmission bolts had gotten loose and screwed up the threads, so i put some helicoils in there and installed the transmission.the guy had that truck for 4-5 years later and never had a problem with them....
#25 |
Would anybody happened to know what size is the thread on the water plug that the heater hose is supposed to be plugged up to?
