Old 10-22-2008, 10:56 PM   #1
69ChevyRazorback
What offset do I need for 6 lug on my truck?
i am looking to buy some 20inch rims for my truck. there are so many differen't offsets. will a regular 6 bolt pattern work for my truck??? also im converting to disc brakes up front but planne don going with 6 lug disc brakes so I could keep my factory drums in the back. will both of these allow for any 6 lug pattern wheel or specific offsets?
69ChevyRazorback is offline   Reply With Quote
Old 10-23-2008, 01:08 PM   #2
69ChevyRazorback
Re: What offset do I need for 6 lug on my truck?
come on guys i know someone has to know the answer to this
Old 10-23-2008, 01:41 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I don't have Twenties, but I have an 8-inch wide wheel up front, with a 4-inch backspace. Out back, the wheels are 10 inches wide, with a 5-inch backspace.
Member Nr. 2770
Old 10-23-2008, 01:43 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
I just pulled a set of wheels off my truck 16" x 8", 4.25" BS.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-23-2008, 02:35 PM   #5
69ChevyRazorback
I am just wanting to know what the offset of the lugs has to be for it to bolt up my 6lug rotors??? Can I buy any RWD 6 lug wheel and it fit
Old 10-23-2008, 02:39 PM   #6
GKsport67
GKsport67's Avatar
...age old question!!!
GKsport67 is offline   Reply With Quote
Old 10-23-2008, 02:41 PM   #7
69ChevyRazorback
lol i know thats why i figured alot of you guys would know this....
Old 10-23-2008, 05:45 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
6 on 5.5 is the bolt pattern. The issue becomes one in which the wheel is hub-centric or lug-centric, which means does the hub do the centering of the wheel or do the wheel lugs/nuts do it? If the wheel is hub-centric, you have to be sure that the wheel will mount to your hubs. There should be a buncha threads on here that people have posted to about which wheels will fit.
If nothing else, go to www.tirerack.com and play with the site and see what they say will fit.
If you looked at www.summitracing.com at some wheels, you'll find that they will state "pre-71 truck", for the 6-lug wheels that will fit.
Member Nr. 2770
