Old 10-22-2008, 11:36 PM   #1
John S
Question about D70 in a 89 1 ton 4x4
I have a 89 1 ton 4x4 454 truck that has a dana 70 in it and the gear code indicates 3.42 gears , i have been looking around at available gearsets for the d70 and all i find is 3.54 . is it possible that the rear gear is 3.54 and front is 3.42 ? eventually i will pull cover and count teeth , but just curios if that was the case , the rear is in the faor sale section and i wanted to be accurate in its listing .
John
John S is offline   Reply With Quote
Old 10-24-2008, 06:23 AM   #2
Re: Question about D70 in a 89 1 ton 4x4
John, what code are you looking up to deteremine that it is a 3.42?
I am not positive but I vbelieve yor research is correct and that the D70 does not come with a 3.42.
Palf70Step is online now   Reply With Quote
Old 10-24-2008, 08:40 AM   #3
John S
the code in glove box is gu6 which is 3.42, vin also matches glove box sticker
Old 10-24-2008, 08:38 PM   #4
This page lists that gear for it ( I think I read it correctly)
http://www.drivetrain.com/gm10.5.html
Now I do this alot, as I am not a super rearend guy (well at least not on truck...women though )
You sure its a D70 and not a 14 bolt GM Corporate?
Old 10-24-2008, 09:56 PM   #5
John S
cover has only 10 bolts , i know because i have 10 fingers and there is only one bolt per finger lol
Old 10-24-2008, 10:12 PM   #6
Well, I am lost then. GM version 10-bolt has that code and ratio, but like you said, no D70 with that ratio.
I wonder if it was swapped out from what came in the truck?
Edit....By your picture that is not a Dana, that is a GM 10 bolt
Old 10-24-2008, 10:19 PM   #7
John S
the dana site shows a dana 70-3 hd with 3.42 gears for 871/2 to 89 k30 but truck is a k3500 , if there is a difference and no its not a 10 bolt its a full floater axle
what picture you talking about ?
Old 10-25-2008, 07:20 AM   #8
Ahh, never mind John. I looked at the wrong axle for sale ad
Old 10-27-2008, 09:28 AM   #9
K30 and K3500 is the same thing,1t 4wd.I didn`y know any Dana was still used after the end of the`70s.I think those codes are screwy.They are probably 3.54s.That`s a Dana ratio and I doubt theres another that close.I think that may be the tallest gear Dana offered in 60s and 70s.
Old 10-27-2008, 11:36 AM   #10
b454rat
My 89 had the 70 in it when I first got it. And Dana 70s were used up to the late 90s in a bunch of different applications. If the tag is GU6, it has 3.42s. The Dana 70 3HD is a screwy axle, it doens't use any other D70 stuff, other than wheel bearings of stuff like that. Dana expert lists it on their site too...
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 10-27-2008, 02:41 PM   #11
HotRodYJ
HotRodYJ's Avatar
Drop the cover and look at the numbers on the ring gear. That's the best way to tell for sure.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 10-28-2008, 12:10 PM   #12
Huh,thanks.I never caught that before.
Old 10-23-2010, 06:53 PM   #13
86454k30
86454k30's Avatar
I just bought an 89 K3500 SRW, it too has a Dana 70 with 3.42 gears.
86454k30 is offline   Reply With Quote
