10-23-2008, 01:13 AM | #1 |
Junior Member
stepped lower control arms/ raised ball joints???
anyone done it? I have 3" springs & drum brakes on my 67. I wanna keep the drums cause I'm cheap...
are 67 - 72 lower control arms the same, just the ball joint different? I have a pair off a 72 & would like to do them so I can just swap them out...
frontstreetcycle on Instagram |
10-24-2008, 03:31 PM | #2 |
Re: stepped lower control arms/ raised ball joints???
Yes, the arms are the same, the ball joints are different. Here's a pic for reference.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
10-24-2008, 06:27 PM | #3 |
Never thought of that one before. I've seen the spring pocket lowered, but not that one. Does this cause alignment nightmares?
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
10-24-2008, 09:06 PM | #4 |
Texas Big Wig
Im pretty sure this used to be a common thing "back in the day", but I wasnt around then
10-24-2008, 09:27 PM | #5 |
its all about the +6 inches
it was common.
If you are working it yourself, i think I'd recomend making the spring pocket deeper. That would be easier to judge how much of a drop you get, and no chance of messing up where the ball joint sits (screwing up the alignment) I have a set, on the burb. I'm still not 100% sure they are gonna be on there long term. I don't think mine were built right. With no shims in there, I still have my wheels sitting like this; \----/ Not to that degree, it is very mild, but enough to eat tires if I don't do something soon. |
10-24-2008, 09:49 PM | #6 |
Junior Member
longhorn...yours have the balljoint raised?
any one have pics of the spring pocket lowered?
10-24-2008, 10:18 PM | #7 |
yeah, i may be mistaken, but that might actually be my photo. not sure.
But I DO know this is mine; |
10-24-2008, 11:09 PM | #8 |
Junior Member
looks like about 1"? I am thinking 2"...I will look into the dropped pocket. There is a guy not to far from me that does a TON of bags & lowered cars & trucks. I may ask him some stuffs...
10-24-2008, 11:19 PM | #9 |
Had mine for a long time......got them before all this other cool stuff was available.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
10-25-2008, 12:14 AM | #10 | |
Junior Member
3" lowered springs & 2" stepped lowers?
frontstreetcycle on Instagram Last edited by scrapmetalart; 10-25-2008 at 12:24 AM. |
10-25-2008, 08:15 AM | #11 |
blood type; Retumbo
mine used to have 3" lower buckets. that netted me a 5" drop. I also changed the angle of the ball joints to keep them in the middle of their arc. to do this I did 2 small slits and heated the arm while gently bending the ends. my way ended up with a neutral camber curve. the problem was the coils would rub on the inside of the pocket and make a ugly noise.
10-26-2008, 12:37 AM | #12 |
Never Ending Projects
I had a set of "dropped A arms" from So Low Suspesions (back in the day). The first set were too wide and I could not get my camber even back to 0*. They sent me a second set which worked fine. Only issue I ever had was without any bumpstop, I overflexed a new upper ball joint and distroyed it. I replaced it and sold the truck soon after (not for that reason) so I never made any bumpstops, which would have fixed that issue.
Outside of that, they worked fine.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-26-2008, 12:46 AM | #13 |
My buddies dropped a-arms (aftermarket So-Lo/Chisolm) worked fine up until the day one of the dropped spring pockets snagged a man-hole cover in his neighborhood. Bent the frame like a cartoon. . ..... the damage was baaaaaaaaaaad.
Stepped stock arms (like pictured) will work; but they'll have the same draw-backs vs. upgrading to drop-spindles.
10-26-2008, 08:40 AM | #14 |
a drop spindle would have snagged on the same thing there.
In a dropped LCA that is properly built, I don't see any drawbacks over a dropped spindle. |
10-26-2008, 12:36 PM | #15 | |
I disagree.
The reason why is these were aftermarket dropped a-arms (which I indicated). The spring pocket was about 1.5" below the same lowest point vs. the stock lower arm it was swapped for. Quote:
I feel properly stepping a set of stock arms would be similar to dropped spindles.
10-26-2008, 02:07 PM | #16 |
I missed that part.
Thanks for the correction. |
10-28-2008, 11:58 AM | #17 |
MY 68 3/4 had steped lower arms from So-Low, I put a lot of miles on that truck and I still see it driving around once in a while.
i still miss that truck... Steped lower arms and cut coils, back in the day... Mick |
10-30-2008, 07:51 PM | #18 |
Too many toys,not enough money
Post deleted
New thread started Last edited by MT71c-10; 10-30-2008 at 08:02 PM. Reason: started new thread. Too many questions |
