Old 10-23-2008, 09:41 AM   #1
Critter
Future TOTM Winner
Critter's Avatar
Question Full Body Powder Coat?
I have an idea that I don’t think I will ever get around to doing so I figured I would share and see if any of you guys have ever done it/like it. Has anyone ever COMPLETELY powder coated a truck body? Obviously, it would have to be done during a frame off when the cab is bare, bed can be disassembled (maybe not depending on oven size), etc. I don’t think it would be quite pretty enough for a show truck, but a 4x4 that actually sees some trail time but still gets shined up from time to time might be pretty awesome like this. Anybody have any thoughts? Would the finish build up too much for the door and fender gaps? I would consider doing this to my Blazer, but I don’t know if it would be possible because of the size of the tub.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 10-23-2008, 09:47 AM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Full Body Powder Coat?
I was wondering when you were gonna ask this.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-23-2008, 10:27 AM   #3
ColoradoK5
ColoradoK5's Avatar
Thats a good idea. I don't think build up would be a problem. I think the effects of the amount of heat the panel is exposed to would be my biggest concern. but if it is going to be an off road beater/dd qualtiy + i think it would be ok. Might want to test a few decent bedsides and see how they react to the heat. Good luck!
ColoradoK5 is offline   Reply With Quote
Old 10-23-2008, 10:42 AM   #4
big_al_71
big_al_71's Avatar
I think it would be awesome. I have had motorcycle frames, swingarms powder coated and never had an issue I cant see how it would be an issue on a body....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-23-2008, 10:46 AM   #5
panhandler62
Java Mechanic
panhandler62's Avatar
How well will powder coating hold up to little dings and panel flex?
I usualy see pretty solid parts powdercoated. It's extreamly scratch resistant but I wonder if it will stay conformed to parts that aren't entirely rigid.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 10-23-2008, 11:10 AM   #6
SactoJim
SactoJim's Avatar
A couple other things that come to mind that may or may not be an issue to you.....
Powdercoating is electrostatically applied (bare metal) so panels would have to be as straight as possible without any fillers (bondo). If any body panels ever got damaged, you may have to replace the entire panel no matter how small the damage is unless you are very good at metal finishing. The whole panel would have to be powdercoated again and I would wonder how well color match would be.
Automotive paints have UV protection in them and I would wonder the same about powdercoating......will it "chaulk up" over time due to exposure.
Just some thoughts that come to mind with my limited knowledge of powdercoating.
That said......it sure would be as durable finish as you could get short of bed lining the whole truck!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-23-2008, 11:14 AM   #7
mr48chev
mr48chev's Avatar
The local powder coater has a hood that his shop did as a demo unit for the show room and to take to car shows. It looks good but magnifies every flaw in the metal. As the other guys said, it will only work on bare metal.
Old 10-23-2008, 11:44 AM   #8
Critter
Future TOTM Winner
Critter's Avatar
I did think about that, just forgot to post it. I believe they make metal body fillers, right? As long as it could conduct the electrical charge and handle the heat it would work. The heat might be the biggest issue with this. Either way, it would be hard to get it as straight as a traditional body filler plus it would probably be more time consuming and costly than regular paint. I still want to see it done...just with someone elses money!
http://www.automedia.com/Getting_the...es20041001ld/1
Old 10-23-2008, 11:57 AM   #9
d10s69c10
Built 4 Speed
d10s69c10's Avatar
More thoughts.
Never have to wax it again.
Almost scratch proof.
Copper/Silvervein.... or even nuclear lime..
yes powdercoat is somewhat flexible as far as body panels flexing. dings im afraid it might be a bit brittle for that..
im still stuck on color possiblities.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 10-23-2008, 01:06 PM   #10
nightmare
nightmare's Avatar
critter take a look at this: poison dart
this car was at the lone star nationals for the goodguys show. has a hemi too!
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 10-23-2008, 01:26 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
DAMN! Apparently I have good ideas...I just have them after someone else has already done it.
Old 10-23-2008, 03:56 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
hot rod magizine did this 2 years ago or so.
Personally, if it is a driver, i think it is a bad idea.
Old 10-23-2008, 04:09 PM   #13
ulakovic22
With Longhorn on this one. Look up Project F-Bomb and you can read about what has to be done to make a powdercoated body work. It's good if you have the body sandblasted and then powdered to stop any rust, but to do body work etc you have to grind it all the way down in that area and then prep for paint. As far as I know painting over it isn't that big a deal and the whole body will be protected just like when you dip a car. It will get in places that a spray gun can't.
ulakovic22 is offline   Reply With Quote
Old 10-23-2008, 04:13 PM   #14
Aunt-Jemima
If you can get the bondo thing to work it would be a great investment. I've powdercoated all of my quads and it's pretty much scratch proof it will withstand bends and such. Great investment
1969 c20 350/th350(shift kit) A/C cab custom headers and exhaust
1972 c10 307/th350 (wrecked) possibly selling
Aunt-Jemima is offline   Reply With Quote
Old 10-23-2008, 04:20 PM   #15
ulakovic22
I agree if you are good with metal work do it. You can't powder once you have done any body work with filler. When you bake the powder to cure it you will soften the filler. If you want to finish the car with powder then everything has to be metal work.
Old 10-23-2008, 08:56 PM   #16
Longhorn Man
If it is a driver, I recomend looking at the frame rails of a semi (18 wheeler) before spending the money.
Powder isn't as good as what so many people think it is.
Old 08-23-2017, 03:50 PM   #17
kernsey
Yes it can be done...were doing it now
www.facebook.com/87pitstop
kernsey is offline   Reply With Quote
Old 08-23-2017, 05:15 PM   #18
StingRay
StingRay's Avatar
An ambulance manufacturer that I worked for many years ago powder coats entire ambulance bodies. They have a powder oven you could drive a semi tractor unit into. They use an epoxy based filler with excellent results. I have a can of it at home.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-22-2019, 11:12 PM   #19
66C10LB
A friend of mine (who has several C10s) just used this method for his cab...
Sand blast then powder coat as a primer layer
Send off to the painters to
Scuff, prime, block, base coats, clear coats.
66C10LB is offline   Reply With Quote
Old 07-23-2019, 02:23 AM   #20
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Makes some sense to me. That and if it's dinged you have to pull the part. If it's the cab then big BUMMER.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-23-2019, 06:33 AM   #21
This is pointless. Just use good paint. Why over complicate things? Powder coat is not the immaculate invincible end all coating some like to see it as. It has it's place
Old 07-23-2019, 08:54 AM   #22
66C10LB
......for me, I am not planning to powder coat body parts. Just good primers, high build, blocking, base and clear.
Old 07-23-2019, 09:41 AM   #23
chewychevy67
I don't have Facebook so I can't view this. I wonder how it is looking now?
chewychevy67 is offline   Reply With Quote
