10-23-2008, 02:06 PM | #1 |
Pitman Arm Removal
How do i get it off the spline end?
10-23-2008, 02:09 PM | #2 |
1970 C10
Re: Pitman Arm Removal
I came to the same problem when i needed to get my PS assembly off, and ended up using a gear puller, worked pretty easy.
10-23-2008, 02:14 PM | #3 |
If you have an orielly auto parts store there they have a free loaner tool program. Just leave a deposit..
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
10-23-2008, 02:18 PM | #4 |
Always on the hunt...
There is a tool/puller available at most auto supply stores, some parts houses have them for rent also.
10-23-2008, 02:23 PM | #5 |
Is the puller specific to pitman arms?
10-23-2008, 02:32 PM | #6 |
10-23-2008, 02:46 PM | #7 |
Hey, just noticed you are only in Sherwood. Are you ever in the Portland area running errands, if you have your steering gear removed off of your truck, then drop in/come by and I will remove the pitman for you?
10-23-2008, 02:52 PM | #8 |
I actually go to school right next to Mall 205, and I think your right down the street arent you? Thanks for the offer! Im gonna look into a puller, but if I cant figure it out I will come looking for you
10-23-2008, 02:53 PM | #9 |
Once I get it off, how do I get the new one back on?
10-23-2008, 04:15 PM | #10 |
I just went and bought a puller like in the picture, and it doesn't work. I clamped it on and tightened the sh*t out of it, even breakin out the cheater bar. Then I read the directions on the package and it said to hit the center pin with a hammer, so I tried that. Still no luck. Any ideas?
10-23-2008, 04:36 PM | #11 |
Firefighter
Put some penetrating oil on it and with the puller under tension hit the side of the pitman with a hammer and it should come off!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
10-23-2008, 04:43 PM | #12 |
Alright thanks Ill give it another try
10-23-2008, 05:07 PM | #13 |
Restoring it $200 at a time...
Marinade for a day in SiliKroil, then the puller and a BFH will work great.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
10-23-2008, 07:57 PM | #14 |
sharp as a marble
like with all things, you can buy a WAL-MART brand puller, or a SNAP ON PULLER. Some of those pitman arms can be a bugger. A good puller, and a BFH, will usually get them off. Some of the steering boxes are master splined ( meaning the pitman arm will only go on one way). I would make sure the truck is going straight ahead, and that the steering wheel is centered. pull the pitman arm, going slowly, and have the new one ready to put right back on. I don't remember what size socket it is, but put the arm on, and the nut and lock washer, and tighten the crap out of it and you will be fine.
10-23-2008, 09:31 PM | #15 |
Well I bought a cheapo NAPA one so its probably crappy
10-23-2008, 10:09 PM | #16 |
Moderator
You can get one at harbor freight also. It does not have to be a snap on top-of-the-line tool, as you are only going to use it once.
10-23-2008, 10:30 PM | #17 |
That was my thought, I will probably use it maybe once again
