Old 11-23-2002, 08:09 PM   #1
hanssolo
hanssolo's Avatar
Question Who runs a Crane 210/210 @.050 cam?
Anyone using a Crane 210 single pattern with the .440 lift? If so, how so you like it?
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 11-23-2002, 09:04 PM   #2
bigjimzlll
bigjimzlll's Avatar
havent run one..but thats what I wouild consider a "RV" cam..very mild..good torque down low..probably a smooth idle with atleast 19 inches of vacuum
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-23-2002, 09:41 PM   #3
Mike C
Mike C's Avatar
That's the Crane Energizer 266. I have one in my Jimmy. It is an awesome truck cam. Pulls to about 4500 rpm. I plan on running the same cam in my 427. It is very well suited to the gear spread in an SM465.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-23-2002, 10:27 PM   #4
Gene
Gene's Avatar
I agree, I am running that cam in my 350 w/headers and Edelbrock 600 and RPM intake. Good Idle, plenty of vaccum and pulls to my tach limit lol 5000. I run 3.07 gears and they like that cam...
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 11-23-2002, 10:56 PM   #5
MikeB
MikeB's Avatar
In my 383, it's a pretty mild cam, but will pull like crazy from idle to 4500. After driving with it for a while, I retarded it 4 degrees to shift the power curve upwards a couple hundred rpm, and added 1.6 rockers. The idle got a little lopey, and the peak revs increased from 4900 to 5100. Of course, in your shorter stroke 350 it would probably have these same characteristics installed straight up with 1.5 rockers. I think it would be a great daily driver cam in a 350 with 9:0 CR. If you have stock heads and/or exhaust manifolds, I would get a cam with more exhaust duration, like Crane's 210/216 PowerMax.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
