Old 10-23-2008, 11:03 PM   #1
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
TBI 5.7L retro into ’72 questions
A while back I fell into a real good deal on a wrecked 85,000 mile 1990 G-Van with a TBI 5.7L and 4L60 that I couldn’t pass up. I figured I would toss this contraption into my old beater truck to give it some modern amenities such as EFI and OD. I didn’t plan on doing the actual engine swap until Christmas break but I advertized the 350/Th350 from the ’72 on CL and it sold tonight and I have to yank it out this weekend. So, it looks like I will be dropping the new engine and trans in much sooner than expected. Now I have play money to buy a TBI harness too!
My question is what are you all doing for a fuel pump to run TBI? Does anybody make a fuel sending unit with in-tank fuel pump provision for the in-cab fuel tank yet? If not, I don’t mind using a frame mounted pump on this truck even though the frame mounted pump on my ’78 with the 8.1L isn’t working so well. Any suggestions on a decent frame mounted pump for TBI?
Also, I saw something awhile back for a speed sensor in the trans that also runs an electric motor for the speedo cable. I searched but couldn’t find the thread. Who makes that gizmo?
Does the TH350 shifter linkage at the trans work on a 4L60 (700R4)?
New powertrain after a hot bath, fresh paint, tune up parts, etc.
DirtyLarry is offline   Reply With Quote
Old 10-23-2008, 11:15 PM   #2
boostin20
boostin20's Avatar
Re: TBI 5.7L retro into ’72 questions
Aeromotive sells great inline pumps that will handle anything the 5.7 or 8.1 can put out.
boostin20 is offline   Reply With Quote
Old 10-23-2008, 11:45 PM   #3
DirtyLarry
DirtyLarry's Avatar
Very true, but in the case of my ’72, I don’t want to put a $400 fuel pump on a $300 truck. I was hoping to hear success stories of cheap discount auto part store house brand pumps that will muster up enough pressure to run TBI. TBI is pretty low pressure anyway.
The 8.1L truck is in the process of being converted to an AC Delco EP241 Corvette/F-body in-tank pump. That truck generates too much heat on the trails for a frame mounted pump to work very well….or for very long.
Old 10-24-2008, 02:12 PM   #4
DirtyLarry
DirtyLarry's Avatar
Nobody, huh?
Old 10-24-2008, 03:20 PM   #5
LEEVON
LEEVON's Avatar
If I'm not mistaken, TBI factory pressure varies from 8-13 psi. Here's a pump/regulator combo from Summit that should do the trick. Also check out the thread on fullsizechevy.com called "ulitmate TBI mods" or something similar.
http://store.summitracing.com/partde...5&autoview=sku
EDIT: Would it be possible to use an 87-91 blazer/burb tank with the internal pump...maybe could save a few $$$
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-24-2008, 04:19 PM   #6
Ackattack
Ackattack's Avatar
I was thinking that the TBI was a low pressure system too.
However, I used a frame mounted fuel pump for my TPI 350 and I didn't have any problems with it.
I think this is what I used
but you may want something a little different if the TBI is a low pressure system.....do some checking.
Ackattack is offline   Reply With Quote
Old 10-24-2008, 06:19 PM   #7
Rust Buster
Rust Buster's Avatar
I bought the Walbro frame mounted pump when I did mine, and it includes both a pre and post filter. Bought it from Arizona TPI.
I used it for 2 months or so and then started a frame off restoration. Still have it and it is for sale if you are interested. Worked great.
I have no use for it now since I went with a mass-flo system that requires a higher pressure in-tank pump.
Here's a link to the Walbro pump I have
http://www.aztpi.com/product.php?pro...4&cat=1&page=2
Yes the TBI requires low pressure about 10-13 PSI
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 10-25-2008, 05:23 PM   #8
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
I used the Carter P5001 pump on A Jeep Wrangler that I converted to TBI a few years ago. It is self priming and it can put out about 15 PSI max. It worked very well and never had any issues. Glad to see someone is actually using EFI on the older vehicles instead of taking a step backwards and slapping a carb on a good running EFI engine!!! Airtex also makes one, but I like the construction of the Carter unit better. If you want an Airtex just tell the counterman that you have a 1982 Chrysler Imperial with a 318 w/ fuel injection. It is the same pump!!!!
Summit sells the Carter pump for $131 and it is the best price I have found lately even with their 'handling' charge.
http://store.summitracing.com/egnsea...5&autoview=sku
Hope this helps!!!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 10-26-2008, 12:42 AM   #9
DirtyLarry
DirtyLarry's Avatar
Thanks for the info guys.
You would think someone would have created a 67-72 fuel sending unit with an in-tank fuel pump provision by now with all of the EFI swaps going on with these old trucks as frame mounted pumps really aren’t all that dependable due to overheating. This ’72 of mine is just an old beater that usually just gets hand-me-down parts so I am not looking to spend a much on a fuel pump if I don’t half to. I have a frame mount pump that is coming off of the ’78 but it is a high pressure pump intended to run multiport EFI so regulating that pump down is an option I suppose.
The only reason this ole girl is getting an EFI and OD swap is because I fell into a cheap van with all the goodies and I was hoping Vhatozone, or Checker Auto had a $20 pump that would work. I snagged the sending unit out of the donor G-van so I am thinking of trying to coble pieces of the G-van sending unit to the ’72 sending unit to create an in-tank fuel pump with the pieces I already have on hand.
I spent the afternoon pulling the 350 and TH350 out of the ’72 today then gave it a gave it hot bath for the guy that purchased it.
Just before the old powertrain was removed…..
The old powertrain waiting to be picked up by it’s new owner. He said he was putting this into a 2wd S10 Blazer.
Old 10-26-2008, 09:54 AM   #10
BlueJeep
BlueJeep's Avatar
I've always used the Master E2000 from Auto Zone. It's around $80, the application is from an 89 F150 IIRC. Been running them for years, and I've had just as good of luck from them as from Walbro pumps...for a lot cheaper.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
