Old 10-24-2008, 12:54 AM   #1
kissingbug1978
Big Block engine swap
How hard is to swap a big block into these trucks. I know that I've seen it before. But just don't know what kind of mounts to use or where to locate them on the frame. And anything else that might be involved. Or potentail headaches.
kissingbug1978 is offline   Reply With Quote
Old 10-24-2008, 01:06 AM   #2
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: Big Block engine swap
Beauty of chevy a 4.6 and a 9.3 will fit in the same mounts just about.
simply put no its not that hard if you have a complete motor to drop in.
"common" issues will be radiator Exhaust front springs.
really depends on how stout of a engine you are throwing in, but everything from the back of your crankshaft to your wheel studs could also factor in.
for those who are guessinga 9.3 is a 572. whats a 10.3?
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 10-24-2008, 01:43 AM   #3
kissingbug1978
The engine I'm currently looking at is a 396 with stock internals and the usual bolt-ons(intake,carb, headers and a decent cam). I'm not looking to get to crazy here as my truck is planned to be a daily driver with an automatic overdrive tranny. I guess the question I was trying to ask is, Is it just a matter of changing the mounts and dropping in the engine. Or is it more involved?
Old 10-24-2008, 02:47 AM   #4
leftcoast66
leftcoast66's Avatar
Basically is just like swapping smallblocks. Very simple in these trucks. I believe ece or one of those places has some big block mounts, and then the radiator I'm not sure about, but you get the picture. Its simple.
leftcoast66 is offline   Reply With Quote
Old 10-24-2008, 06:58 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Check with CHEVYFLEETSIDE....he is currently working on one on his back-burner.....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-24-2008, 08:39 AM   #6
kissingbug1978
thanks for the info as I've not been able to find it anywhere else on the net.
Old 10-24-2008, 10:27 AM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
Here is my thread so far. You don't have to go as far as cutting the firewall. That was a personal choice. http://67-72chevytrucks.com/vboard/s...d.php?t=259536
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-24-2008, 12:38 PM   #8
BRASSHEAD
BRASSHEAD's Avatar
I have a 402 in mine. I cut the fire wall, made the cut out wider and deeper. I also trimmed the frame about 3/4 of an inch and modified my motor mounts to clear the manifolds.
BRASSHEAD is offline   Reply With Quote
Old 10-24-2008, 01:38 PM   #9
steverino66
Here's my 454.
I had to get some 68-72 big block frame mount towers to fit the header on the driver side (#2 tube was hitting the small block tower).
I mounted mine on the forward holes on the frame rails to clear the firewall with teh valve covers. I'll have to have a driveshaft cut to fit. Requires some patience, but it can be done.
steverino66 is offline   Reply With Quote
Old 10-24-2008, 03:24 PM   #10
BRASSHEAD
BRASSHEAD's Avatar
Sorry about the picture still learning.
Old 10-24-2008, 03:41 PM   #11
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
10.3 is a 632ci? i might be wrong but im sure 604ish is about 10L so somewhere in there (im probably wrong but im only 19 so i usually am)
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 10-24-2008, 11:18 PM   #12
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Got it!
496/T-56 in worx.
Old 10-25-2008, 11:01 AM   #13
502tripower
502tripower's Avatar
Here is my 502. If you use the 73' up motor mounts Its a drop in. You may have to re-drill the top of the frame rail. I had to massage the passenger side fire wall a tiny bit. Also by using the 73' up mounts you can then buy headers for those models that fit much better. Good luck.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 10-25-2008, 11:51 AM   #14
protrash64
Resistance is Futile
protrash64's Avatar
I would follow 502's route unless you know of a 67-72 to get BB parts out of. I had everything to do this and ended up not doing it; maybe I should have as I wasted alot of $$$$. (Im usually good at sticking to my plans)
Pulling the engine forward also gives you alot of clearance BB or SB in these trucks. I dont see many people do it on here, however. Should not be super difficult to get it done if this is your plan. good luck
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-25-2008, 01:23 PM   #15
BRASSHEAD
BRASSHEAD's Avatar
If you want to run tall valve covers you will need to cut your fire wall or move the motor forward.I did not move mine so I would have room for a fan,plus I like the smoothed and recessed firewall.I have been thinking of trying the short style headers for chevelles.Ground clearance is an issue for me.
Old 10-25-2008, 04:55 PM   #16
Captainfab
60-66 Nut
I did on my '66 Burb, mainly so I could run taller valve covers without cutting the firewall. Of course I had to fab some custom motor mount brackets. Only moved it 1.5"to 2".......it's been so long ago I can't remember for sure
