Old 10-24-2008, 03:04 AM   #1
ERASER5
ERASER5's Avatar
I need to fab...
some U-bolt straps. I recently put 2" blocks under my leave springs ('70 GMC). Yes, I raised it. The block kit had new U-bolts instead of square-bolts like the factory. So the bolt plate that was under the axle, is now on top of the leaf springs. The fit is horrible, but I had to get thing back together.
Since the spring is a continuous arch, I was thinking about two 1/4" plates about1-1/2" X 5" or so each across each spring pack. Four plates total. A single plate would need to be contoured or it would only touch at the edges. Any thoughts?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-24-2008, 09:15 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: I need to fab...
You will need to make it one piece rather than two. The plate is used to locate the center pin in the leafs too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-25-2008, 12:04 AM   #3
ERASER5
ERASER5's Avatar
Only the nut is on the top side. The location pin is under the spring pack locating the lift block which has a locating pin for the axle. The top plate should not need locating, but I suppose I could weld a bent strap between the two straps. That would be easier than one solid plate.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 10-25-2008, 01:39 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, I see now. So what was the question again?
Articles-
"Refining Sierra"
Old 10-25-2008, 08:27 PM   #5
71blaze
If you want to do it right just buy some new bolts that work for your application. It will cost a little more but you will be happier.
71blaze is offline   Reply With Quote
Old 11-02-2008, 12:46 AM   #6
ERASER5
ERASER5's Avatar
I found my answer in the junkyard. I spied a Cherokee w/o wheels so the axle was exposed. There was a nice top plate. Better yet, I got them free! The guy was either in a good mood or too busy to mess with a couple bucks worth of metal. They worked perfectly!
Good thing too. The former bottom plate/now top plates had shifted and ALL eight nuts were loose. Not sloppy loose, but not tight and not good.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 11-02-2008, 10:23 AM   #7
SevenOne
SevenOne's Avatar
Good find.
SevenOne is offline   Reply With Quote
