Pitman Arm Removal
The stupid puller isnt working. Ive beat the **** out of it with a sledge. Is there something im doing wrong? Is there something holding it on that needs to be taken out first?
busted knuckles
Re: Pitman Arm Removal
You sound as frustrated as me. I would push mine off a cliff if I could get it there.
Haha ya i love these old heaps but when nothing you try works, its easy to get angry
busted knuckles
Mine is one step forward and two steps back. I need a second one to beat the crap out of when something goes wrong with the main one.
Ya perfect excuse to get more
Moderator
![]() Join Date: May 2007
the puller should work with no problem...did you lube the crap out of the arm?
Ive had it soaking in WD40 for the last day/night. Do I need something more powerful than WD?
I am a Referee of life.
WD-40 is not a penetrating oil.Get some Kroil,PB Blaster,or liquid wrench.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Moderator
Restoring it $200 at a time...
Kroil from the manufacturer:
Kanolabs.com
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
install puller tighten up then wack the puller stud hard with heavy hammer then tighten again wack wth hammer //the tension on the arms combined with the shock of the blows with the hammer just a little movement each time till it breaks loose
You gotta try this stuff sometime guys. I is a welder/engineer and am using it more and more. Great stuff to have on the shelf/ in the tool box. Might be just what you need, oh and what cdowns said.
http://www.henkel.com/cps/rde/xchg/S...8_USE_HTML.htm Bill.
1972 K2500 Long Box 400/350 |
#13 |
Alright thanks guys. After repeated attempts the BFH won
#14 |
blood type; Retumbo
they ALWAYS come off easy for me.
I use a cuttoff wheel to make a slit in the arm almost to the splines being carefull to not hit the box. then I use a puller and it slides off real easy. no pounding or other form of abuse involved. |
#15 |
I guess I got lucky when I changed the pitman on my '71, hooked the three jaw up and turned it with a breaker until the pitman popped lose. Brute force won that day (probably didnt hurt that the dang thing was already tryng to work its way off). My major headache was the dang idler arm but alittle "liquid red wrench" aka blow torch helped with that.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." [Cherokee saying] 2001 Dodge Ram Sport 1500 4x4. (old ride) 1987 GMC V1500 Sierra Classic ("new" ride) |
#16 | |
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#17 |
I have found that by using Kroil and if practical, heat, you can get almost anything apart.
#18 |
Ya I found that out. Definitely made it easier
![]() I had to use my torch on the idler arm too. Filled up the garage with smoke, it was awesome. I feel bad laying so much abuse on something directly tied to the steering box. Oh well you gotta do what you gotta do Last edited by LuckyHenriksen; 10-25-2008 at 11:14 AM. |
