Old 11-23-2002, 11:20 PM   #1
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
Goodmark doors
Iam wondering if anyone has bought the goodmark doors for the 67-72 chevy trucks? What is your opinion on them good bad or indifferent!
Also what about the door skins anyone use the repop skins?
If they are no good whats your favorite location for picking up a pair of doors for a 72? Thank you...Eric
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 11-23-2002, 11:51 PM   #2
guypm
I have 2 new Goodmark doors and would not recommend them to my worst enemy. If you have any stock doors, do all you can to use them. they will fit much better. when i lined up my new doors, they almost rub at the rounded top part of the door. the lines are close enough, but to do it over again, i would cut out the rust from my old doors and weld in new patch panels. i did buy a tailgate from them and it fits great. i know that most aftermarket parts probably would need to be modified, but the doors i've heard and seen do not work well at all. i read a few weeks on a post that someone couldnt get theirs to even fit in the opening. he threw away several hundred dollars. stick with the old if at all possible. hope this helps,
Guy
guypm
1971 SWB Fleetside/350 performer rpm heads &intake/ holley 750dp/1.5roller rockers/MSD6a/700r4
1650stall/one piece driveshaft/3.73 open/dynomax ceramic coated headers/3chamber flowmasters/
guypm is offline   Reply With Quote
Old 11-24-2002, 12:51 AM   #3
frost89434
frost89434's Avatar
I had the same problem that guypm had. I also got a set of new fenders and they were a pain to work with. The holes for the core support were way off. And also the curves between the door and the fenders aren't the same.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
