11-23-2002, 11:36 PM | #1 |
Can't Change Air From Vents To Heater
Anyone have advice for problem with the HVAC system on my 72 K5. I can not divert the air from the vents to heater or defroster. When I move the control lever, the cable moves arm on box. I can also hear the flap moving inside the box. But the air continues to come out of vents. Any recommendations or advise would be appreciated.
Thanks in advance. ...Dan |
11-24-2002, 12:39 AM | #2 |
I've had the same problem. The diverter flap was broken along the bar where it rotates. I ended up super gluing it back together and it works. You could also by a new diverter box or a salvage yard piece, but I'm cheap.
11-24-2002, 02:37 PM | #3 |
Thanks Ack.
...Dan |
11-24-2002, 08:11 PM | #4 |
My other Love
Isnt there a rubber gasket around the door? If there is it might be all cracked
I had a similar problem on my 77 silverado, turns out the heater box was full of pencils, pens, nails and a screwdriver. Don't store crap on the top of the dash
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
11-24-2002, 11:41 PM | #5 |
Thanks Hooter!
I plan to get into this weekend. ...Dan |
11-25-2002, 01:25 AM | #6 |
newly minted old timer
ya im sure its that door. it breaks right near the pivot pin. im even cheaper than you guys, i got 2 large washers and some really good epoxy. glued 1/2 the washer on the door and the other 1/2 on the part still connected to the pin.. works well. almost 2 years no trouble
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
11-25-2002, 09:48 AM | #7 |
Thanks MT.
Looking forward to it not costing much. ...Dan |
11-25-2002, 10:22 AM | #8 |
Keepin' It Stock
Want a really cheap fix? Here's how the PO solved the problem. Works ok but it can be a little tricky to close or open while you're driving. I decided to go with a new box.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
11-25-2002, 04:18 PM | #9 |
So Many Ideas, So Little Money
I was thinkin about doin somethign lke the last pic, but I'm not sure what you guys are sayin is broken. mine I took apart to replace the heatr core last winter and it didn't work whn I got it togeter, took it apart and pushed the flap up so it was in the heater vent direction. summer, I slide the lever and it goes back, took itapart this fall to flip it again, and just recently the defrost to heater changer stopped workin. I can move the slide but it stays at little on defrost, rest of heater(floor)
any ideas?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
11-25-2002, 11:49 PM | #10 |
ttt
11-26-2002, 01:31 AM | #11 |
That is deffinitely cheap Johnnyp.
Chevy2racr I think my problem is with the first diverter controlled by the ac. ...Dan |
11-29-2002, 04:09 PM | #12 |
any ideas for me to look for?
11-29-2002, 07:35 PM | #13 |
I am not an expert, and not sure I understand your problem, but it could be cable related. Is your cable moving diverter arm required distance?
...Dan |
