Can anyone tell me what the heck this stupid bump is?
I want to box in my frame but do not know what this does or if I can shave it. Anyone know? Thanks.
Blazer Project |
its all about the +6 inches
Re: Can anyone tell me what the heck this stupid bump is?
that's clearance for the fuel pump on the big blocks. No clue why they raised it instead of trimming it.
So if I dont run a big block I can "square-it-off"?
Blazer Project |
you can bend it, trim it... what ever you want. It isn't doing anything in all reality, big block or not.
ive always thought it was clearance for the oil filter on the inline 6's
![]() Last edited by 68 short step; 10-24-2008 at 10:28 PM. |
it showed up in 68, the same year the big block did ... and 67s had the inline (both sizes) and no flair in that location.
Plus... if you look real hard in this photo... ![]() |
ahhhh, i learn somethig everyday......
i can see the clearance issue. So, is this a pic of a big block? And, is a small block going to have this issue?
Blazer Project |
yes, that is a big block, and no, there is plenty of room on a small block.
Very cool...I'm off cutting and welding. thanks!
Blazer Project |
born to lose
You do learn somthing everyday on this board. I thought that lip ment my frame was bent on my 71 and now I know its not. Hooray!
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 ![]() '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 ![]() Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
![]() Join Date: Nov 2001
i'm might be wrong but , i think it's bent up for the clearance of the fuel pump as said and still keep's the frame strong instead of a cut out . i'll have to check out my 67 now , way cool ... thanks for the new info
#13 |
NGN, you are correct. It is a way to create clearance and add vertical stiffness to the frame in that location. Boxing the frame will accomplish the same thing, as long as there is no interference.
#14 |
Yeah,I wouldn`t just go trimming that and leaving it.That flare is still giving alot of strength on the verticle plain.But,boxing it will make it stronger yet.
I`m curious.Why are you boxing your frame?
#15 |
Im just going to cut it and box it in. I jus have to figure out how to get to the lower cross member bolts now.
Blazer Project |
#16 |
My 67, which came with the inline six has the flair as well.
#17 |
Out of the carpool lane.
That bend is on my '67 and is for the oil filter on a 6!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 10-28-2008 at 03:44 AM. |
#18 |
son of a...
Well....thanks guys. |
#19 |
classic=of recognized value
I think it might be cancer. If it isn't in the way I would leave it alone.
#20 |
Sorry man, but my '67 has it too and it is definitely a 67 frame because it doesn't have the stupid notch for the power steering...
![]() The pic sucks, but it's there.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#21 |
My 67 frame has the "fin" as well. Now all we need is the Jimmy Buffet song.. "fins to the left, fins to the right"
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
#22 |
M y 67 had it and it was a inline 6 and the long filter fit nicely my current 68 big block model has it , the fuel pump is lost in that area .....
#23 |
![]() Join Date: Sep 2001
The 6 oil filter does look like the original reason for the frame tweek. I'll be dipped in ....
#24 |
I guess the question now is, does the 60-66 frame (which I understand to be very similar to the 67-72) have the same notch, presumably for the oil filter change?
Edit: After a bit of searching, it appears the 60-66 trucks have the notch as well, it looks a little different, but it IS there. Borrowed this from ChiefRokca's build thread: ![]() Another angle: ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-28-2008 at 11:48 AM. |
#25 |
![]() ![]() Join Date: Jul 2002
It probably didn't need the same notch as they didn't use the same 6-cylinder. The 235 CI 6 doesn't have the oil filter positioned in the same location. Also, if I remember right, they didn't use twist on filters then either. We still used the toilet-paper canister filters.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 10-28-2008 at 12:15 PM. |
