Old 10-25-2008, 09:26 AM   #1
Hawker7
Plate under Stock Intake Removal
Anyone know how to remove the plate under the stock 4 barrel intake? Looks like it is riveted in?
Hawker7 is offline   Reply With Quote
Old 10-25-2008, 09:43 AM   #2
toolpimp
too many toys
toolpimp's Avatar
Re: Plate under Stock Intake Removal
Slot them with a thin cutting disc on a hand grinder or ig your steady with a hack saw. Then wack em with an impact driver to loosen.They are spiral rivets but do come out.
if we were all fatter we'd be closer together
1971 gmc 3/4 4x4 383 stroked
1968 1/2 2nd owner 4bbl 6cyl
1969 gmc 3/4 4 sale 350 4bbl 4spd
1969 chev 1/2 lowered 5 spd 454 4bbl
1947 chev coupe
2002 harley flhtcui
6 -67-72 my parts
toolpimp is offline   Reply With Quote
Old 10-25-2008, 10:24 AM   #3
cdowns
cdowns's Avatar
pretty foolish to remove that plate its there to prevent oil being splashed on the hot intake removing will cause sludge formation
Old 10-25-2008, 10:25 AM   #4
Hawker7
want to remove it for cleaning purpose.
Old 10-25-2008, 10:33 AM   #5
Hawker7
This is why I wanted to remove the cover and clean in there. Thanks for the help.
Old 10-25-2008, 11:02 AM   #6
truckdude239
truckdude239's Avatar
holy cow!!!
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-25-2008, 07:26 PM   #7
JimKshortstep4x4
I tap the four holes with a 8-24 tap and use stainless screws to hold the plate on. The tap will bottom out so the last few threads are not cut completely so the screws will lock in place when tightened up.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-25-2008, 10:27 PM   #8
72swbcamo
Active Member
I know this is late because you already have the cover off. When I removed mine I just used a sharp chisel under the head of the rivet and it popped right out. Replaced the rivets in the same hole they came out of . Had to hammer them back in so think they will stay in place.
72swbcamo is offline   Reply With Quote
Old 10-25-2008, 10:35 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
Moroso and Milodon have a super slick tray to take its place. it keeps the lifters in place in the event of a catastrophic valve train failure. it uses 2 spring steel strips between it and the intake to hold it down. I think they go for about $30.
found it
http://www.milodon.com/oil-system/pa...ter-baffle.asp
68C15 is offline   Reply With Quote
