Wood bed idea ?
Has any one ever used composite decking as a bed floor ? If so I would like to see pics and get some info about what brand and size . The only thing I can find is 7/8 thick . I believe the original is 3/4 thick, correct me if im wrong. I would like to go grey floor to match the interior . Let me know what yall think .
Re: Wood bed idea ?
Good idea!
Re: Wood bed idea ?
You mean something like "trex" stuff? That would never need any care that's for sure. The only thing I'd be woried about is flex when it gets hot. I have a deck made of Trex and when it gets pretty hot it starts to have a bit of flex to it, like you can feel it dip as you step on it. Me and my father actually went through and added more braces underneath the deck to solve this problem. Just something you might want to consider if your going to use your bed much. Other than that......PICS
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Wood bed idea ?
i dont know if its improved but any of that junk thats made of recycled soda bottles retains water and therefore if you got any kind of oil or stuff in the bed youd never get it out... it used to black mold easy too.. youd prolly have to put it ontop of plywood too to get it not to flex some.. personally id avoid the idea
Re: Wood bed idea ?
The truck is going to be a show truck so nothing will be in the back I would have to worry about . I cant find any 3/4 " thick its all 1" . Going to home depot here in a few to see If I can find any thing that will be diff looking besides oak or pine . Did a lot of work last few days I wll post some pics later tonight . Any ideas for some kind of diff bed let me here them . Im up for any thing diff
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Wood bed idea ?
Mike Nutt put some in his 67-72 pickup.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
One shot, one kill.
Re: Wood bed idea ?
Franklin. I work part time for a decking company in upstate NY. All the composite decking (walking surface) you find will be "5\4" X 6" or 1" X 5.5". As someone stated it does absorb oil ect and does get soft in the heat. On decks we install using "Trex" or other composites we reduce joist spacing to 14" instead of the usual 16" to reduce "spring". The mold issue has been corrected. Do not, DO NOT use treated pine!!! Chemicals in treated wood attack steel and is especially hard on galvanized and aluminum. Personally I would use oak planks with 10 or 15 coats of laquer and then hard waxed BEFORE INSTALLATION and done on both sides. Lots of work but VERY pretty and durable. Will clean up with soapy water and last for years. Just my two cents, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Re: Wood bed idea ?
I decided to go with oak . So whats a good clear varnish to apply . I was told to use a marine varnish but some of those turn yellow over time . I would like to keep the oak as natural as I can .
Thanks for all of the help so far . Cant get much help from lumber yards around here . |
One shot, one kill.
Re: Wood bed idea ?
Franklin. Don't use varnish. You want to use Minwax spar urathane. This stuff is almost bullit proof. First, sand the wood on both sides and true up the edges on a table saw and sand the edges. Next apply 1 good coat and allow to dry till just tackey, then apply another coat and allow to dry 24 hours. Do the same thing on all 4 surfaces. Next using fine steel wool, dull the shine and apply a good coat and allow to dry. You can apply as many coats as you want, just dry 1 day and steel wool between coats. When your done wait a month and then wax with Butchers bowling alley wax, then install wood and rewax the entire bed. Wood will last a long time and look great for years. jim
Re: Wood bed idea ?
Check this place out for wood. Hi-dollar on some of it.
http://www.bedwoodandparts.com/ListItems.aspx Her is some good information on wood coatings.... http://mar-k.com/wood_finish_testing_i.html |
Location: Where I come from, it's cornbread and chicken...
Re: Wood bed idea ?
how hard would it be to install a wood bed floor in a shortwide instead of a stepside...
Chuck. |
