Transmission crossmember question
I am in the process of swapping an auto tranny in place of a three speed tranny. I have an auto crossmember, column and other necessary parts.
Will I need to remove the manual transmission crossmember to make this swap work? I realize it would look neater, but removing the upper rivets in the crossmember looks like a real pain. The truck is a 70 model C-10 and will never be anything a driver. Any input will be appreciated. |
Re: Transmission crossmember question
We have a truck that was converted from a stick to an automatic and the PO left the stick crossmember in place.
Personnaly I would remove it but it worked for the guy that had the truck before we got it. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
you can use a sawzall and just trim if flush with the framerails
