Old 10-25-2008, 07:00 PM   #1
Hawker7
Plug for wire harness?
I'm getting ready to take my cab off the frame but need to remove the 4 wires that run to the back taillights. Does this just unplug from the firewall? It seems as it might but when I pull on it nothing pops out. I didn't want to damage anything so I didn't try too hard.
Hawker7 is offline   Reply With Quote
Old 10-25-2008, 07:16 PM   #2
JimKshortstep4x4
Re: Plug for wire harness?
It just unplugs as you suspected. If you pull on the lip it will help. Also spraying it down with a soapy solution and wiggling it around will loosen it up. There is a male plug on the inside that you should unplug before attempting to pull the outside plug out.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-25-2008, 07:44 PM   #3
Hawker7
yep, that worked just like you said. Thanks
