![]() Join Date: Apr 2005
402 BBC and stuff F/S (Albuquerque, NM)
*** Possible trades, buddy buckets...... ***
I don't know the mileage, but it was supposed to have run before it was pulled. It comes with Holley Aluminum valve covers, Holley factory steel intake, new fuel pump, new spark plugs, exhaust manifolds, Holley 750 carb (looks nearly new) and a turbo 350 tranny (probably needs rebuilt). $550 o.b.o. Block: 3999290, T02090 TBH Heads: 3999241. Complete inner and outer heatcore, fan, and controls $80 shipped.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-05-2009 at 01:48 PM. |
Re: 402 BBC and stuff F/S (Albuquerque, NM)
Forgot to mention I've got a turbo 350 I will throw in with the deal.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
you got casting numbers on heads and block?
A...........
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
I believe engine block is 3999290, but I'll double check and look at the heads. The numbers on the front of the block are: T02090 TBH
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-27-2008 at 01:45 PM. |
Is the carb a 4779C?
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
I believe its a 3310, dual line feed, 750 cfm.
Rob, $550 for the whole package with trans? If so I may be interested, if diesel decides not to?
BTW: Both numbers point to a 72 402 2-bolt FYI TBH 70 402 Truck 310 L-47 Manual 4-Brl All Models 3999290 402 72 2-bolt Last edited by 70rs/ss; 10-27-2008 at 01:52 PM. |
#8 | |
I changed it, looks like this one is a bit more peppy that the other? I need another BBC like I need another hole in my head, but the intake is something I'd like to get and $550 isn't too steep if it'll run. I'll ask but not sure if you need anything? I have too much stuff and a lot of parts? BTW I haven't been back to PHX, but should be in DEC and I can try to get the seat? LMK
#10 | |
R/
Not interested in 2-bolt block.......If heads are good casting may be interested in them if will part out.
Thanks for reply, A........
Thanks, but I prefer not to part it.
#13 |
Looks like your up next 70RS/SS. Let me know.
#14 |
Diesel what are the heads worth to you, cause I have Vortecs I'd use, and it would help me out?? I'll PM you and get back with you Rob.
#15 |
Got your PM.........just depends on the casting.
A..........
#16 |
I know they are the stock heads but I haven't gotten the numbers yet.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-31-2008 at 03:49 PM. |
#17 |
Ttt
#18 |
I pulled the valve covers and the head numbers are 3999241.
#19 |
Bttt
