Old 10-25-2008, 10:28 PM   #1
Moose67
Moose67's Avatar
12 Bolt Casting Numbers
I need help figuring out what 12 bolt I have. Or lead me in the right direction to find the info.
The numbers on the axle tube are WE 11 12
right axle tube facing front of truck center section is 3838227
left side center section facing front is GM 5
I am doing conversion to 5 lug and need to make sure the parts will work. Thanks.
Also what is the outside diameter of a stock 67 driveshaft?
I posted this in the suspension section and got nothing. Sorry for the re-post but I need your help.
Moose67 is offline   Reply With Quote
Old 10-26-2008, 09:01 AM   #2
JimKshortstep4x4
Re: 12 Bolt Casting Numbers
A quick check to see if (5) lug axles will fit in your 12 bolt is to measure the distance between the backing plates. The 71-72 axles are 56 1/2" between the plates while some of the 70 and older are 55".
On the drive shaft question, is your truck 2 wd or 4 wd?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-26-2008, 12:59 PM   #3
Moose67
Moose67's Avatar
It is a 2wd
Old 10-26-2008, 06:23 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
You can go here and select the year in the axle codes section.
http://www.americanclassic.com/paint_test.asp
You need to double check your code though. I don't find a WE....
LockDoc
Leon
