Engine n00b
1970 c10 with 71 power steering
I pulled the following from a 71 today...
What other parts do I need to swap this in? ANything? ![]() |
Re: 1970 c10 with 71 power steering
im not too sure i would said get what you can i do have power steering from a 1971 chevy truck too and it is on my 1967 chevy 3/4 ton long wheel base 4speed a/c truck
its all about the +6 inches
i don't see brackets to mount the pump on the engine.
Here is a picture of the pump and brackets as they are fastened to the engine. The brackets are the ones that Longhorn Man noted were missing in your pic.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Engine n00b
Yea, found that for $30 on ECE... Anything else it look like I need (other than a WHOLE lot of degreaser?)
I don't see a small clamp that clamps the two lines to the frame. If you look at the attached pic it can be seen holding the lines in place. Without it the lines will come in contact with your fender liner.
Jim
