Old 10-26-2008, 01:23 AM   #1
68Timber
I know the pieces fit
68Timber's Avatar
Rear axle question...
From everything I've read, my 79 2wd Blazer should have a 10-bolt rear but it has a 12-bolt.
Could this be factory? Not that it matters, I'm just happy to have a 12-bolt. But I was plenty surprised. Any chance this axle came stock on the truck?
Thanks.
Old 10-26-2008, 04:26 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Rear axle question...
I thought the 10 bolts started showing up in these trucks around 1981-82.
Keith
Convert to disc brakes.
Old 10-27-2008, 11:19 AM   #3
blazn79
I had my 79' on the lift today and it has a 12 bolt as well
and it's definitly the OG rearend!
H.
blazn79 is offline   Reply With Quote
Old 12-05-2008, 12:28 AM   #4
turbotank
turbotank's Avatar
me thinks it was about 84 that they started putting the bigger 10" in the trucks blazers,suburbans,etc. A 79 will definitely be a 12-bolt
The general is always in charge
You guys did this to me!!!!!!!!!!!!!!!!!!!!
turbotank is offline   Reply With Quote
Old 12-05-2008, 01:56 AM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The 12 bolt ran from 73-81. The 10 bolt ran from 78-91 So 79 could of gone either way...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-06-2008, 06:42 PM   #6
68Timber
68Timber's Avatar
It's a pleasant surprise. 4.10's and an Eaton Posi will go well there and stand up to what I'm putting in front of it.
Old 12-07-2008, 09:13 AM   #7
tvblazer78
Low & Fast!
tvblazer78's Avatar
12 came in mine and I put a 4.10 in too. Works good, but the the best with a 3 speed like me.
tvblazer78 is offline   Reply With Quote
Old 12-09-2008, 08:34 PM   #8
68Timber
68Timber's Avatar
This will be a cruise-in special, but I'd still like to get a 700R4 put in before the gears. I'll find out this weekend...
Old 12-10-2008, 02:45 PM   #9
turbotank
turbotank's Avatar
Yeah,that .7 makes a huge difference in rpms!!!
