manual trans problem
ok i just got this truck not to long ago its a 1991 4x4 gmc with a tbi 350 n 5 speed trans and when i got it i was told it had a recent clutch in it and the motor has around 7000 mile on it. anyway my problem is that recently it has been im possible to get in to gear when i start it but if i started in gear once i started moving it would start to shift fine but if i let it sit for more than an hour or so it would start all over again and today i changed the fluid in the trans and in the clutch line and after that i went to watch the local mud boggs and it sat for about five hours and when i got in it to go home and i couldnt even get it to go into gear when i tried starting it it moved the truck. and i couldn't even pump up any pressure. what me n my dad are thinking is that it may be the clutch line? i see no leaks by the slave or master cylinder or even inside the truck. what im thinking is that i it might be letting air into the line while it sits?
what do yal think?
91 gmc k1500 chevy grill power buckets 350 5 speed |
![]() ![]() Join Date: Jul 2002
Re: manual trans problem
This may sound dumb, but did you bleed the clutch cylinders? It sounds from what you saying that the clutch is not engaging. I know on the S10 the slave cylinder is inside the bell housing, but I can't remember about where the slave was on my 92 C1500.
The S10 I had acted like yours, but I was lazy for a long time and babied it so I wouldn't have to pull the housing to change it. I sold it to someone else and helped him change it.
Yeah there is a way to bleed the slave and master. And the slave is on the passenger side of the tranny, you can access it pretty easily. When I got my 88 with a 'new' cough cough tranny I had to bleed and replace all the fluid. I agree, I would bleed them. Check your reservoir also and monitor for any fluid loss after the change. Also consider the slave may be 'going', and as I hear, they are usually the first of the two to die.....(cry) good luck.
-Bikerbomber
If all men are created Equal* does that mean we are all artifical?
yes i did bleed the system ant it helped for the trip out n by the time i went to go home it was bad again
It is sounding more to me like the slave or master (or both) cylinder are bad on the clutch.
thats what i thought at first to. but if that were the case wouldnt i be loosing fluid?
![]() Join Date: Sep 2005
no i jsut went though this at work if the mc has an internal leak you wont lose fluid but you might not be able to be pressure in ym case it was a ford escape sometimes it worked sometimes it didn;t it was fixed by replaced the clucth mc
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
hmmm i never knew that i guess if a new line doesn't fix it ill try that next but i just seen where it looks like some one had cut the line and put a joint in it so i wanted it replaced anyways but i guess if it donet fix it i'll be lookin up the cost on a new master
well i figured it out it was the hose like i suspected although the slave cylender wasnt far behind two days after i replaced the hose it went on me thanks for all the help
| Bookmarks |
