10-26-2008, 10:54 AM | #1 |
Sierra Grande Club
Do the r4 type trannys use same oil cooler lines as 350?
I'm looking a new set of stainless oil cooler lines for my 350 from Year One.
But I'm also considering a upgrade to the r4 type transmission in the future. I don't want to spend the money to just replace them again. Is Year One good to deal with? Don't hear much about them on here. I'm guessing they are not a vender here? I've considered using rubber lines, but the 4 fittings will run as much as the lines. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
10-26-2008, 11:11 AM | #2 |
Re: Do the r4 type trannys use same oil cooler lines as 350?
you can use the same lines the inlet and outlet are in about the same place on both trannies, //you just need adaptors for the fittings,my tranny guy included them with the tranny when i got it
