Old 10-26-2008, 08:44 PM   #1
GOPAPA
GOPAPA's Avatar
Not sure what I will do ,,,, got any Ideas ?
I am about to install a new poly blazer tank in the rear of my truck frame .
I am going to use the filler neck from a doner truck that will fit in the rear corner of my bed .
The filler neck will be one from the extra tank that trucks have that the filler neck is located at the front of the fender up high on the inside of the bed . The same as the blazer filler tube I am told..
This type of filler neck goes straight up the inside of the bed side and turns out through a hole just like the cab filler necks do ..except that this filler neck in the bed has a (chase as I call it ) that hides the filler neck and protects it all the way up to where it sticks out of the bed side .
My truck is already painted and I would rather not weld onto the bed side to anchor the chase and filler neck and here is one reason why I ask of opinions on this what I am about to do..
I have a picture to show where I want to locate the filler neck and chase I have yet to get ,,I used a filler neck that I had only to illustrate where I am talking about.. The filler neck I have yet to get is one that I can turn complete opposite of the way it fits (180 degrees) ..that way it will enable me to put the gas hose nozzle into it to fill my tank.
click to enlarge the picture .. thanks for reading such a long exclamation .. papa
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 10-26-2008, 10:14 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Not sure what I will do ,,,, got any Ideas ?
Seems like you would have to glue or screw the chase/cover to the inside bed panel. I would think that the filler neck could be fastened to the inside of the chase/cover.... Just some thoughts.
LockDoc
Leon
Old 10-26-2008, 10:47 PM   #3
GOPAPA
GOPAPA's Avatar
LockDoc
yeah ,,If someone had a real good glue so I could glue the chase to the bed wall and screw the chase to the corner post hole ,,might just be the ticket..plus screw the chase to the floor ,, never though of using glue,, thx papa
Old 10-26-2008, 11:14 PM   #4
Husker
Husker's Avatar
Thats kind of how I did mine. I used a Blazer tank and fill from a mid 70's Blazer.
Worked out pretty good, when I get the bed Coated it will look better. I have already redone the cover, these are older pics.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 10-26-2008, 11:35 PM   #5
GOPAPA
GOPAPA's Avatar
[QUOTE=Husker;2947222]Thats kind of how I did mine. I used a Blazer tank and fill from a mid 70's Blazer.
Ron[/QUOTe
thx for the look,, are you just using the brackets on the post corner and maybe floor for fastening the chase or are you fastening also to the fender .
and if so How? papa
Old 10-26-2008, 11:43 PM   #6
Husker
Husker's Avatar
I screwed the filler Neck Top to the top of the cover. The cover is just screwed on incase I need to get in there.
I have the hose clamped to the frame underneath. The wires are for extra grounding. I also shortened the filler neck so it would fit better. Cut out section then welded up.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 10-27-2008, 10:31 AM   #7
GOPAPA
GOPAPA's Avatar
Ron
thanks for sharing ,,did you use the original chase or make a new one and did what did you make it out of if you did? papa
Old 10-27-2008, 10:59 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Any paint store should have the metal glue that you can use.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-27-2008, 04:37 PM   #9
70rs/ss
70rs/ss's Avatar
panel bonding adhesive (most new cars have some form of epoxy holding them together, it is better than welding so they say, and in your case will be perfect.
70rs/ss is offline   Reply With Quote
