Old 10-26-2008, 10:26 PM   #1
kissingbug1978
Talking LS1 Swap
Anyone done this? I've got an opportunity to get an LS1 Complete with tranny for "about $1500". It would come with wiring harness, computer, and all accessories. Just wandering what all I'm looking at here.
Thanks.
kissingbug1978 is offline   Reply With Quote
Old 10-26-2008, 11:08 PM   #2
olsofti
olsofti's Avatar
Re: LS1 Swap
I done 5.3 4L60e from a 2003 Silverado,about the same swap.
You'll need the vats turned off in the pcm,motor mount adapters,and a crossmember for the trans.You can make it run using 3 wires and the stock fuse block or do a custom harness.
I made the mounts and modified the crossmember myself,but you can buy them if you want.
There are many sites dedicated to this swap.You can search this site and LS1.com,ls1truck.com.and lt1swap.com is probably the best Brendon can even reprogram your pcm.
Do a youtube search for ls1 or 5.3 engines to see them running "stand alone".
Hope this helps.
olsofti is offline   Reply With Quote
Old 10-26-2008, 11:38 PM   #3
Hoffman65burb
Hoffman65burb's Avatar
Re: LS1 Swap
ooo cool! im planning on putting a vortec( 6.0 or 5.3) in my burb. Do you have any pictures of the swap?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
