Old 10-27-2008, 01:11 AM   #1
LeDevil
A new C10 Addict!
LeDevil's Avatar
Power brakes but not so powerfull
I have a 67' C10 with power brakes and well up until tonight I thought I had manual brakes. The brake pedal only moves about 1/2 a inch and when pressed I have to put quite a bit of effort in pressing the pedal to stop the truck. The truck feels like it wants to jump some times when sitting at a light. What should I look for to fix my issue? Thanks LeDevil
LeDevil is offline   Reply With Quote
Old 10-27-2008, 08:07 AM   #2
chrismoore701
chrismoore701's Avatar
Re: Power brakes but not so powerfull
2 things in my opinion, I guess one question and one thought. Do you have 4 wheel drums? I would say it could be a vacum leak?
chrismoore701 is offline   Reply With Quote
Old 10-27-2008, 10:24 AM   #3
kizer
Its Deja Vu time again
kizer's Avatar
1/2 inch of slop moment in the brake pedal before the brakes activate or you only have a total of 1/2 of movement in the brake pedal total?
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 10-27-2008, 01:37 PM   #4
LeDevil
A new C10 Addict!
LeDevil's Avatar
chrismoore701: Yes it has 4 wheel drums, Where would you think the vacuum leak would be? How would I check for that?
kizer: I have a total of 1/2 inch of movement there is no slop.
Thanks for the reply's guys
Old 10-27-2008, 05:13 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
swap to disc brakes up front.
Keith
Convert to disc brakes.
Old 10-28-2008, 04:42 AM   #6
umwtnt
umwtnt's Avatar
If I remember correctly, you should be able to put your foot on the brake pedal with the engine off, Start the engine and the pedal should go down some. If it doesn't then your power brake unit is bad. You can check the hose to the unit for vacuum leaks.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 10-28-2008, 07:56 AM   #7
chrismoore701
My dad has a corvette with 4 wheel drum, not power, and you better pray if you need to stop fast. As for checking for vacume leaks, what I do is take a can of carb cleaner and spray near the vacume hose, if there is a leak, it will suck the cleaner into the engine and the engine will rev higher. check the hose and connections. good luck
Old 10-28-2008, 09:11 AM   #8
HotRodYJ
HotRodYJ's Avatar
Originally Posted by LeDevil View Post
...The truck feels like it wants to jump some times when sitting at a light. What should I look for to fix my issue? Thanks LeDevil
I'm guessing automatic? Sounds like the idle might be a bit high compounding the problem.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
