Old 10-27-2008, 07:38 PM   #1
gmclowsierra
axle splines
does anyone know how many splines are on the axles of 8.5 10 bolt rear axle for an 85 gmc 2wd 1/2 ton? ive seen 28 and 30 splines. is there a way to find out without pulling the axle and counting? also are the 8.5 axles the same width from 73-87 to 88-98 and what splimes are they? thanks for the help JOE
gmclowsierra is offline   Reply With Quote
Old 10-27-2008, 10:04 PM   #2
85 c-10
Re: axle splines
My 85 C-10 1/2 ton had 28 spline. Once I blew it up I put 33 spline Moser parts in. Thats all I have to say about that.
Josh
85 c-10 is offline   Reply With Quote
Old 10-28-2008, 09:43 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: axle splines
If your axles are still stock, they're 28 spline. They changed over to 30 spline in the 10 bolts sometime in the late 80's, not sure exactly what year.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 10-28-2008, 10:35 AM   #4
454HO
Re: axle splines
Splines for the 8.5" rear changed from 28 to 30 in '88 or '89 depending on the vehicle model. And from the research I did a while back, the 30 spline axle shafts for the '88-'98 truck are a little longer (like 1/2") than the 28 spline shafts on earlier years.
I did not find an off-the-shelf direct fit axle shaft to convert from 28 to 30 spline carrier. Would have to have some custom made. Not a big deal, but maybe $100 or so more than direct fits would cost.
- Greg
454HO is offline   Reply With Quote
