Stock Proportioning valve
Heres what I want to use on my 69 step---I converted it to disk front only(from a 85) and I want to use a stock master and booster from the 71 type for disk-drum combo.I can buy the stock type for under $100 but I cannot find a stock type proportioning valve anywhere,anyone actually know where I can buy one? Thanks Chip
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Stock Proportioning valve
If your local parts store dont have one
http://www.inlinetube.com/Prop%20Valves/pro_valves.htm |
"THE GREEN GOBLIN"
X2 InlineTube
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
![]() Join Date: May 2002
IIRC i got mine from ECE: http://www.earlyclassic.com/catalog.aspx
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 10-29-2008 at 08:52 AM. |
#5 | |
Active Member
![]() Join Date: Jul 2007
Mike's bump and grind here on the board was the most reasonably priced when I did my drum to disc swap. I di get my lines from inline though.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
I tried repeatedly to re-set the prop-valve on my 74 following instructions from here but it wouldn't work so I just got a new one & haven't had a prob since (7-07). I used Inline-Tubes valve & 4pc front stainless hardline kit.
