Old 10-28-2008, 11:49 AM   #1
72bigred
1960 1/2 cab bushings
Hi all, I am about ready to set my cab on the frame and need some input on exactly what I should do. From my understanding they no longer make the correct bushings for the 60 trucks. I have read here on the forums where people have used some 50's truck body bushings and others state just to use the repop 64-66.. I will go with rubber and want to know what the best way to go is and has anyone found any major quality difference between the companies that make them.. Possibly a pic of what you did and how it turned out? My main concern is the height and how everything will line up apon assembly. Thanks
72bigred is offline   Reply With Quote
Old 10-28-2008, 01:21 PM   #2
83burban
Re: 1960 1/2 cab bushings
I'm using urethane bushings on my rebuild - 63. As long as you use the same bushing for the cab and the radiator support they should line up just fine.
83burban is offline   Reply With Quote
Old 10-28-2008, 01:34 PM   #3
Captainfab
60-66 Nut
I can't help with your specific question, but if you want to compare what you need versus the mounts for the '63-'66 let me know. I've got several here you can look at and I'm not too far from you.
Old 10-29-2008, 04:17 AM   #4
fake.happy
low_standards
fake.happy's Avatar
I used the 64-66 cab bushings on my 60. Had to trim a little off the sides of the bushing because the cab mounts aren't as wide. I faintly remember having to use 2 of the original bolts also but I don't remember if it was front or back.
If you ever need help
don't hesistate to ask
someone else first
fake.happy is offline   Reply With Quote
