Sierra Grande Club
Who is running stainless transmission cooler lines?
I ready to order new lines and not sure if stainless steel is the way to go.
Anyone using stainless with good results? Should I just save my $ and get mild steel? I’m getting them from LMC if that matters. ![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Active Member
![]() Join Date: Dec 2003
Re: Who is running stainless transmission cooler lines?
I used SS trans cooler lines. They fit well. I think I bought them from Inline Tube. They really look good.I think they are worth the extra money. I also used SS brake, fuel, and vent lines, and SS E-brake cables.
If you up my posts you can see pics of the frame. Look for a post named camo truck progress. Last edited by 72swbcamo; 11-01-2008 at 04:36 PM. |
I got a set for my truck and one for my son's. Mine seem to be doing real well (hanging up in the shop). My son can't seem to stay off dirt/gravel at 2" ride height. They are holding up pretty good and the best thing is they won't rust. You shouldn't have any problem with that.
I have an Astro van originally from the Baltimore area and the fuel lines on that are just about gone. The question is, how many times do you want to replace them? Last edited by 71tahoe; 10-28-2008 at 04:57 PM. |
Active Member
i put on AN flex lines ( Jegs Pro Flo 350) and have no desire to go back to hard lines.
You can run these tucked in the frame rail all the way to the front, easy, light weight and not bad price wise
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
#5 | |
"THE GREEN GOBLIN"
1968SWBBigBlock Do you have any Pictures of your setup I am also in the need of Transmission Cooler lines! I was thinking of going the InlineTube route Great prices! But Flex Lines this sounds interesting!!!! Thanks
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#6 | |
I run stainless hard lines on all my transmission coolers.
Sierra Grande Club
I ended up ordering them from Wes. His come from inline tube.
I was disappointed to find out that LMC’s are imported….. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 10-29-2008 at 02:08 PM. |
