Old 10-28-2008, 04:49 PM   #1
EVL GMC
lift kit ?s
i have a 69 gmc k20 what kind of drive line mod will i have to do with a 6inch lift?
EVL GMC is offline   Reply With Quote
Old 10-28-2008, 11:42 PM   #2
jrdv
jrdv's Avatar
Re: lift kit ?s
You will need to have both driveshafts lengthened, longer brake lines, and longer shocks, plus a more comfortable seat!
jrdv is offline   Reply With Quote
Old 10-29-2008, 03:27 PM   #3
EVL GMC
Re: lift kit ?s
thanks,do you know how i find out how much i need to extend the shafts.
Old 10-29-2008, 03:32 PM   #4
jrdv
jrdv's Avatar
Re: lift kit ?s
You will have to put the lift kit on first, then you measure between the transmission yoke and rear end. Ujoint to ujoint.
john
Old 10-29-2008, 04:08 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: lift kit ?s
John is definitely right, you won't know how much you need to modify the driveshafts until the lift is on. A 4" lift usually doesn't require front driveshaft changes but when I did a 4" lift on my 69 K20, it did require changes.
I had to lengthen the front shaft, then when I installed it I had interference and had to have a double cardon joint installed and the shaft had to be shortened. Keep that in mind so you don't have to have yours done twice like I did.
You will also need to make steering modifications with a 6" lift. If you have the closed knuckle Dana 44 you wil need an adjustable drop drag link. Mine is from Skyjacker or Superlift, can't recall which. The raised steering arm that usually is used on an open knuckle Dana 44 won't work on the closed knuckle Dana 44.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-29-2008, 04:18 PM   #6
jrdv
jrdv's Avatar
Re: lift kit ?s
Thanks Yukon
I forgot about the steering arm. I changed it out on one 4" lift and left it stock on the other. All of mine already had a cardon joint, maybe somebody changed out the driveshaft on yours.
john
Old 10-31-2008, 06:33 PM   #7
EVL GMC
Re: lift kit ?s
how can i tell if i have an open or closed knuckle,also i thought i had a dana 60 front axle,anyway to tell?
Old 10-31-2008, 08:54 PM   #8
msgross
msgross's Avatar
Re: lift kit ?s
send pics...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-03-2008, 01:52 PM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: lift kit ?s
If the axle is stock, it will be the closed knuckle Dana 44. No Dana 60 front axles were used in the 67-72 4wd's. Here is a pic of the closed knuckle portion of a 1969 Dana 44.
And here is a pic of a Dana 60 from a 1984 or 1985 1 ton. You will note it uses 3 u-bolts and on the passenger side there are two studs instead of another u-bolt.
