Old 11-24-2002, 03:42 PM   #1
ocbaud
Garage Queen Material
timing problem
i got my timing tab put on today. and me and my friend set my timing with his timing light. its supposed to be 8 degrees stock right? well mine is WAY above that now, because anything lower than 12 degrees and the truck dies.
ocbaud is offline   Reply With Quote
Old 11-24-2002, 09:44 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Stock for my smog is 4 degrees. Are you using manifold vacuum at idle?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-24-2002, 09:51 PM   #3
bigd65
bigd65's Avatar
G,
did you ever recurve your distributer, if so do you still have your timing set at 4* and do you get spark knock at WOT. what kind of gas do you use.
i guy on C/T told me that the XE262 in my truck builds alot of cylinder pressure and i probably need to run super unleaded. i am going to try that next, i have put super in it before and never noticed a difference in performance or milage but that dont mean i didnt get any change, i may have just not noticed it.
anyway back to my original reply, mine is set at 4* and i still have very minor clatter at WOT but dont during regular driving even playing around unless i open it up
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 11-24-2002, 09:52 PM   #4
ocbaud
nope, vaccum is plugged. i dont have my egr or air pump though
