Old 10-28-2008, 10:50 PM   #1
MN Rooky
1971 4X4
MN Rooky's Avatar
E-Brake Help
I'm finishing up on my truck after 2 years and I just tore into the rear brakes. I took apart the drivers side and replaced what I needed to and moved on to the other side. When I got the drum off I noticed that the e-brake cable wasn't attached to anything. I take it I'm missing the e-brake lever in the drum? I would think that is suppose to be on both wheels? This is a picture of the drivers side brake showing what is missing.
MN ROOKY
1971 Chevy 3/4 4X4, 4" lift, 33's
2001 Chevy 3/4 4X4 HD, 33's (Wife's Truck)
MN Rooky is offline   Reply With Quote
Old 10-28-2008, 10:53 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: E-Brake Help
Your missing the crossbar and the spring. I think you can get both at the parts store
dwcsr is offline   Reply With Quote
Old 10-28-2008, 11:14 PM   #3
MN Rooky
1971 4X4
MN Rooky's Avatar
Re: E-Brake Help
Neither side had the cross bar or springs. Do those parts go on all drum brakes? As you can tell this is my first brake job. If it matters it's a 1971 3/4 4x4
Thanks jeff
MN ROOKY
Old 10-28-2008, 11:54 PM   #4
cdowns
cdowns's Avatar
Re: E-Brake Help
yes most all drum brakes will have the crossbar and spring//print out the picture take it with you to a NAPA store and they should have everything you need in stock
Old 10-29-2008, 12:55 PM   #5
kyull67
kyull67's Avatar
Re: E-Brake Help
Good luck at the parts store, most likely the bar will be too small. I had to go the the salvage yard to find mine.
kyull67 is offline   Reply With Quote
Old 10-29-2008, 08:57 PM   #6
MN Rooky
1971 4X4
MN Rooky's Avatar
Re: E-Brake Help
yep,
The parts are too short at the part store. I will be running without a e-brake until the salvage yard god smile down on me. So I will be looking for 2 crossbars, springs and right side e-brake lever. It may take a while to find them around this area. Thanks for the drum brake 101.
MN ROOKY
Old 10-29-2008, 09:34 PM   #7
Stock72c10
classic=of recognized value
Stock72c10's Avatar
Re: E-Brake Help
If I were you I would spring for a wheel cylinder rebuild kit as it looks like yours are leaking. I also always get a new spring kit (they are only about $3 per side). You might as well get it done right if it is apart anyway.
Stock72c10 is offline   Reply With Quote
Old 10-29-2008, 09:38 PM   #8
Stock72c10
Stock72c10's Avatar
Re: E-Brake Help
Here's a diagram that might help with terminology. This is what your brakes should look like.
Old 10-29-2008, 09:40 PM   #9
MN Rooky
1971 4X4
MN Rooky's Avatar
Re: E-Brake Help
Thanks,
I got those parts replaced.
MN ROOKY
Old 10-29-2008, 10:21 PM   #10
Brad
Out of the carpool lane.
Brad's Avatar
Re: E-Brake Help
Hey, I think I have all those parts you need and was about to set them out on the curb with the rest of the scrap steel. It appears you need 2 crossbars, the PS ebrake adjuster and the spring it rests on? Let me know and I'll clean it all up and send it to ya!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-01-2008, 01:03 PM   #11
Brad
Brad's Avatar
Re: E-Brake Help
So guys will the 1/2T parts work for him or will they be too short?
Old 11-01-2008, 01:22 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: E-Brake Help
Before you head to the parts store, you should know both the diameter of your drums and the width of the shoes.
Member Nr. 2770
Old 11-01-2008, 09:21 PM   #13
MN Rooky
1971 4X4
MN Rooky's Avatar
Re: E-Brake Help
Good progress today. I got the brakes put back together (without the parking brake) this morning. My wife helped me bleed them out.
Then I worked on getting the truck started. I have worked on the truck for the past 2 years. Happy to say I got it started. Tomorrow I will try to take it for a drive around the farm.
MN ROOKY
