10-28-2008, 10:54 PM | #1 |
Junior Member
5/7" drop-Do I need to change the stock driveshaft?
I ordered a 5/7" drop from CPP (Grand Slam w/disc brakes) for my 67 CST SWB. I ordered the Grand Slam w/3" (f)springs 5" (r) springs and 2" blocks. They said I also needed their rear "shortened" drive shaft with a slip yoke. I wanted to know if the stock 2 pc drive shaft would work. And if not which is better a 1 or two pc drive shaft. I found a guy in AZ that charges $205 shipped on a 1 pc w/slip yoke. I may put bags on the truck in the future.
10-28-2008, 11:45 PM | #2 |
Fabricate till you "puke"
Re: 5/7" drop-Do I need to change the stock driveshaft?
IMHO, I would run a 1 pc shaft in that sb truck,but.....you will probably have to trim the snot out of the crossmember, or go aftermarket on the crossmember to get the shaft to fit. When you are done, you will have less angles to deal with, & the short base truck will handle a 1 pc shaft nicely. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-29-2008, 01:12 AM | #3 |
67-72 parts collector,…
Good luck with CPP. I hope your experience with them will be better than mine. Get ready for some good stories on why your order "didn't" ship,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-29-2008 at 01:13 AM. |
10-29-2008, 08:12 AM | #4 | |
Tot Roddin'
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-29-2008, 08:12 AM | #5 |
Tot Roddin'
As lolife99 stated, I've ready many different stories about CPP, some good and some bad. Best of luck!
10-29-2008, 09:03 AM | #6 |
I've ordered from CPP on numerous occasions and never had even so much as a hiccup.
good luck and be sure to keep us updated with pics. lots of pics! |
